Old 21-Oct-2004, 00:23   #1
Festa748 Festa748 is offline
Festa748's Avatar
OIl cooler
i have a 748 but it doesn't have an oil cooler on and would like to fit one what else do i need other than the oil cooler and lines
Old 21-Oct-2004, 10:42   #2
There is a small deflector plate that fits behind the oil filter spigot. You'll need one of those to divert the oil through the cooler.
Part number 79920771A
[Edited on 21-10-2004 by nelly]
Old 21-Oct-2004, 11:15   #3
chris99 chris99 is offline
Mood: building the beast
I was thinking about this. Do you all think its a good mod to make?
Old 21-Oct-2004, 11:51   #4
Some 748 bikes did - noteably the higher spec bikes like the SPS and R, or so I'm led to believe.
It will certainly help keep the bike cooler, but you'll need to put more oil in it
Old 21-Oct-2004, 13:42   #5
I think it's worthwhile, especially if you like the odd trackday.
You'll also need to check the exhaust valve cover on the front cylinder has the bosses to mount it from. These aren't cheap!!.........surprisingly enough
Old 21-Oct-2004, 16:25   #6
The reason that 748’s don’t have an oil cooler is that they normally don’t need one because they don’t run as hot as the 9XX bikes. The operating temperature of the bike is still controlled by the radiator and the fan operating temperature setpoints. The function of the oil cooler is to cool the oil - to keep the oil temperature, and consequently the oil pressure, within a designated range for expected riding conditions. However, when you take your road bike to the track, or engage in some spirited riding on a hot day, you can easily push the oil temperatures too high on any bike.
Your oil viscosity selection chart in your owners manual tells you to change to a thinner oil if the expected outside temperatures are lower. Adding an oil cooler essentially shifts this chart, so that now you’ll need a thinner oil for the same riding conditions. Under severe conditions found at the track, an oil cooler allows you to keep the maximum temperatures down, but under street conditions the oil temperatures will drop below the values that the chart serves to promote.
As you can see from the chart, a single modern motor oil with viscosity enhancers can be used over a wide range of ambient temperatures and still maintain adequate oil pressure. So it’s not a sensitive parameter.
During an engine’s development time on a dyno, the oil temperature is monitored to avoid temperatures above 260ºF and below 200ºF to avoid oil breakdown at the high end and excessive pumping losses (and higher pressures) at the low end. These dyno runs are simulations of street riding conditions, but not representative of more severe heat loads during actual track conditions.
So, if you modify your oil cooling system you should monitor your oil pressure and adjust your oil viscosity to assure adequate - but not excessive - oil pressure under all riding conditions. See your service manual for the correct cold idle, hot idle, and running operating pressures.
Under track conditions you should be using a 50-weight viscosity oil to maintain an adequate oil pressure and use a full synthetic oil to give yourself a safety net. A regular oil can begin to lose its film strength at temperatures only slightly above 220°F (105°C), but many synthetic oils can be safely used at temperatures as high as 300°F (150°C) before lubrication-related failures occur.
Specifically, if your oil light begins to flicker at idle because of excessive oil temperatures, then you should consider adding an oil cooler. If you already have an oil cooler, you should carefully straighten any oil cooler radiator fins that were bent from road debris in order to get the maximum cooling from the unit. After you straighten them, attach some protective screening to the backside of the v-piece to prevent future damage.
Some studies have shown that test engines produce optimum horsepower in dyno-simulated racing situations when the oil was between 200-220°F (93-105°C.)
I lost the reference, but one source states: “An engine should never be driven hard until the oil reaches 120°F (49°C). The ideal operating temperature is 175-195°F (80-90°C). It can go as high as 265°F (130°C) for short periods but oil breakdown and excessive oxidation will take place above this temperature.”
Suzuki states, for example, that under racing conditions, oil should be kept at about 190-210°F (88-99°C) and that regular temperatures any higher should be an issue of concern. I don’t know what Ducati’s official position on this issue is, but I’m sure it’s similar.
[Edited on 10-21-2004 by Shazaam!]
Old 22-Oct-2004, 18:49   #7
Festa748's Avatar
been looking do you have to split the cases to fit that diverter plate in the engine for the oil cooler ?
Old 22-Oct-2004, 19:41   #8
No. You unscrew teh boss that the oil fliter screws onto. Fit the plate and then refit the boss.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:40.
