Old 22-Oct-2004, 09:22   #1
Darth Darth is offline
Mood: In Need of some Lov'in
A Question
I have a question to all you long in the tooth bikers!!!
On my way home and just tipped into a corner I encountered a river of water running of the feild and over the road.
So the question that sprang to mind along with a few choice words !!!!! Is Do Bikes Aquaplane??? Or am I just a sissy:P
Also attached is a Pic of my new arrival.
Old 22-Oct-2004, 10:12   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Not round corners they don't!
But it's great fun in a straight line.
try again with the pic darth....
Old 22-Oct-2004, 11:14   #3
ali ali is offline
ali's Avatar
Mood: Damp
I generally try to avoid large rivers, but there was a puddle on the apex of a corner at Silverstone t'other day and the front slid on it every time I hit the bugger!
The scientific answer is probably something to with with there being more weight through the contact patch per sq inch than a car, therefore less chance of a bike aquaplaning. However, I'm sure depth/pattern of tread, sideways shear forces and size of your cahoonas has more to do with whether you're going down or not.
In general Ducatis dislike being ridden into rivers (apart from the odd numptystroodle in off road form)....
Cheers,
Ali
Old 22-Oct-2004, 12:41   #4
I'd of thought in a straight line no, as the tyre profile will push the water sideways, like a boat would going through the water, as a car tyre is flat there's far more surface area in contact with the water.
Going round a corner though.... the same principal would apply apart from your pushing the tyres through a corner, so less grip.
Old 22-Oct-2004, 12:46   #5
NBs996's Avatar
understand your theory jp, but didn't work in practice!
But then again, there was a lot of standing water and a couple more mph than there should've been!
Old 22-Oct-2004, 12:53   #6
Ian Ian is offline
Ian's Avatar
Mood: Still having fun!
Ducati's do sort of aquaplane....they rise over everything, they wallk on water :P
Actually I was once given the scientific reason why a motobike does not aquaplane, - I nodded politly and forgot it instantly - Now on sheet ice, you can feel like you are aquaplaning, I have done it a few times, you just sit there trying not to move an inch leaving all of the controls alone, you even stop breathing, until you are through it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:57.
