Old 30-May-2012, 20:00
jangol jangol is offline
Bikes: 1098s, 749
Grey Swingarm Paddock Stand Bobbins
Hi,
had a look on here but not found anything that helps me @ the moment...
I have a Grey Swing arm 749 bp, I'm using a universal paddock stand with the rubber flat feet, it fits the bike ok, but im not 100% confident on it...
I know the later models (black swing arm) have holes ready for you to attach bobbins...
Has anyone every fitted any to a 749, i.e made holes up etc.... any pics did it work or is it a no no....
What else options do I have, so post back in 2005 mentioned using a single side swing up rear paddock stand??
Thanks in advance
JA
Old 30-May-2012, 20:41
Yes, I'll dig through and post a pic.
here you go.
Old 30-May-2012, 20:43
Bikes: 1098s, 749
Cheers Pal..
Be cool if you can stick a few notes on also around if it made any difference to balance of bike, or didn't you notice a thing?
JA
Old 30-May-2012, 20:48
Yes its very secure when on the paddock stand I use an aluminium Motrax stand with adjustable claws.
Old 30-May-2012, 20:50
Bikes: 1098s, 749
Is that a grey swing arm?
How did you fit them, what was used etc...
JA
Old 30-May-2012, 21:24
JA
I prepared 2 lengths of aluminium bar of 20mm diameter with a 8 x 1.25 thread, 25mm deep. I then milled out the arm to accept the bar. as the arm legs are not symetrical one cutout is deeper than the othe, but just measure from the axle centre down.
I then welded the bar into place, lick of paint, job done.
Old 20-Feb-2013, 19:01
spurs spurs is offline
Bikes: 999s and 955i Daytona
I have used an Abba stand on my previous bike and it fits my 999s ok as well , very stable and worth the money .
Old 21-Feb-2013, 09:18
ABBA stands are ok if you are working on the bike, but it takes 2 to 5 minutes to get in place. Whereas a paddock stand, 5 seconds and walk away.
  #9
Old 21-Feb-2013, 13:08
Agreed but as stated paddock stands are generally a little unstable particularly at that lifting moment when either at the front or back of the bike , there is always a heart in mouth moment but not so with the Abba.
  #10
Old 21-Feb-2013, 15:20
Cranker V2's Avatar
Mood: Green with envy
Thats look nice a very neat job Ghost. simple, easy to use and stable. Ive never been a fan of Russ Abba stands - but I can see the point in using one if you have no stand bobbins on the rear.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:34.
