Old 02-Jun-2012, 01:13   #1
pguenet pguenet is offline
FS - 996 / 916 / 748 race and road parts
Still for sale the following parts. cheaper prices.
See below for pictures.
Fancy parts:
- Pierobon front subframe, can fit standard clock or Digit dash - new price £120
- 998 RS wide track adjustable mag yokes - £1,500
- 16.5" wide track wheels (3.5 / 6.25) - 5 spokes - refurbished in stain black (crack test, etc. done then by Griff in Bristol). The finish is not perfect with some marking on spokes. Includes Dunlop slick tires used for one trackday. £650
- Dymag rear 16.5" wheel with big hub. Gloss black, clean, Wet tire mounted on it. £200
- Brembo 290mm wide track front discs - £130
- Brembo 320mm road fitment race discs (very clean) - £350
- Billet race caliper hanger - £150
- Spacer to mount RS big hub rear wheels on to standard axle - £100
- Slipper clutch - Ducati Performance - ball bearings, basket a bit marked - £300
- Sil Motor slip on exhausts - £200
- Ohlins steering damper - £170
- Titanium front standard axle - new, never fitted - £80
Standard parts:
- Standard 996 dual injector throttle bodies including bell mouths, TPS, subloom, injectors, etc- £120
- Reverse shift pedal - £30
- Standard clip ons - pair £45
- Swingarm black powder coated with chain runners and hub - £150
- Standard rear axle with disc and standard caliper hanger - £50
- Race nose cone - fiber glass - number board - £40
- Carbon fiber mudguard, small crack on bottom, does not affect fitting - £40
- Carbon V piece small crack - £20
- Carbon V piece ok condition - £30
- carbon airbox - originally RS but bits cut off, adapted to standard tank and standard airtubes. Clips only on one side, no side plates. £70
- standard carbon airtubes, bit tatty (no recess for clips, need to rivet small ally plates, bolt missing for indicator mounting on one side, underneath slightly unglued), £70
- Red tank - good, small paint chip, old style Ducati logo, NO pump, no cap - £130
- Water rad - tatty - £15
- 45mm clean system - £50
- Standard 1.6 ECU - £50
- Standard coils + plug leads £40
Collection from South London
Shipping at cost
Can supply photos
Payment by bank transfer - Paypal OK (fees paid by buyer)
Old 02-Jun-2012, 01:23   #2
Photos below
Tank - cap not included
Swingarm
290mm discs
airbox
SIL MOTOR exhaust
45mm system
Reverse shift pedal
Throttle bodies
Rad
Pierobon Subframe
Old 02-Jun-2012, 01:26   #3
Airtubes
carbon mudguard
V Piece
V Piece with crack
Nose cone
320mm road fitment discs
Old 02-Jun-2012, 21:25   #4
AP Thumb brake
Spacer for fitting Big hub wheels to road axle
Slipper Clutch - DP
RS small hub Billet Caliper hanger
(fits standard arm - spacing for race calipers Brembo or Ohlins)
Old 04-Jun-2012, 16:24   #5
aide998tt aide998tt is offline
Hi,
Do you still have the rear alloy sub frame for sale.
Old 04-Jun-2012, 21:05   #6
No sorry - gone
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:25.
