Old 31-Oct-2004, 12:34   #1
steam cleaning
So, I've got the back end off and I want to make all the egine etc sparkly, should I jet wash or steam clean? Any down sides or thigs I need to do first?
Old 31-Oct-2004, 15:28   #2
Festa748 Festa748 is offline
Festa748's Avatar
i wouldnt do either i cleaned my engine with just gunk and some rags just takes a bit longer
Old 31-Oct-2004, 23:27   #3
Agree with Festa. I wouldn't steam or jet wash either.
I use Gunk on the tough stuff, Muc-off and the more softer muck and wash off with one of those plant sprayers. There's a reasonable amount of pressure but not a lot of flow, ie you don't get a lot of water everywhere and they're very controllable as to where the water goes.
the one I got holds 5 litres, you can even fill it with hot water.
Old 01-Nov-2004, 20:18   #4
rcgbob44's Avatar
If you lurve your bike NEVER use a steam cleaner or jet woshur!
Old 01-Nov-2004, 20:49   #5
cool - thanks guys, guess I'll have to do it the hard way!
Old 02-Nov-2004, 14:21   #6
guest1 guest1 is offline
liberall dose of wd40 or duck oil first just to soak into the dried on mucky bits, leave it for half hour then gunk it off. Brings up the casting pretty smart
Old 02-Nov-2004, 15:13   #7
going to pick some up at nec - boy that shopping list is long!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:01.
