Old 02-Nov-2004, 02:02   #1
chris_of_1979 chris_of_1979 is offline
Mood: I'm Bad!
Side-stand.....
Having an early model (1998) luckily I don't have to worry about the electricery being cut when the stand is down - which is a wee bit handy, BUT.........
For the last three years I've never been able to get on with the fact that the stand flips itselft up, at the slightest oppertunity - as it's the type that is meant to be that way.
Is there a way for me to modify it so that when I "kick" the stand down, it stays down until I decide to flip it back up again???
Old 02-Nov-2004, 07:01   #2
Bionicle Bionicle is offline
Bionicle's Avatar
originally posted by Nelly in this topic.
http://www.ducatisportingclub.com/index.php3?M=70
The easiest solution is to use the parts that Ducati fit on the later bikes with the switch fitted.
Part numbers are 75010481A (nut) and 82912602A (plate).
These replace your existing parts and your stand is sorted. Costs about a fiver
[Edited on 2-11-2004 by Bionicle]
Old 02-Nov-2004, 10:31   #3
yellow916 yellow916 is offline
Just don't forget to put the stand up! There's no safety interlock like on a Japanese bike. I saw someone forget at a CSS day at Rockingham earlier this year (and he wasn't doing Level 1 either!) - he was very nearly seriously embarrassed.
Andrew
Old 02-Nov-2004, 21:35   #4
Mood: me in a mood? NEVER!
thought if you do the conversion it will stall once placed in gear..
Old 03-Nov-2004, 02:34   #5
Mark
I think this is only true for the later bikes fitted with a switch on the sidestand. My 916 runs just the same with the sidestand down if in gear or in neutral. Mind you, given the reliability of Ducati neutral switches...
Andrew
Old 03-Nov-2004, 23:41   #6
ils ils is offline
I bought a sidestand cutout bypass thingy from Roy996 on e-bay (about £20) was easy to fit and works perfectly.
Old 04-Nov-2004, 00:01   #7
deej deej is offline
deej's Avatar
just ordered my bits from nelly, under £4 inc p&p
he'll sort you out good and proper
i think im right on this and thats that it wont stall on the earlier models as they have the spring instead of the plates the later models have, thats why changing the two over wont cause any problems, the newer bikes need the bypass to be fitted
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
