Old 10-Jun-2012, 12:44   #1
DSC Member killerBunny killerBunny is offline
Bikes: 1098s, 600ss
killerBunny's Avatar
Diverter plate
Afternoon Gentlemen
On removing the filter for an oil change before Oulton I managed to actually loosen the double threaded nut in the crankcase that came away with the filter. No biggy but obviously on going to throw away oil the diverter plate was in the bottom of the pan. It's shaperd like a question mark without the dot but not sure which way it should go back in. I run an oil cooler so will need to put it back. Any advice would be greatly appreciated.
Old 10-Jun-2012, 13:47   #2
Spjallen Spjallen is offline
It can only really go one way as there is an indent in the casing for the top of the "question mark" to slot into. Skids has put the tech diagrams on my recent post "Gucci oil coolers". It's currently a few pages back but the info still stands. Hope this helps.
Old 10-Jun-2012, 14:56   #3
Hi Dean, the rubber pad at the end of the plate closes off a hole whilst the other end of the plate butts up against a raised feature in the crankcase, This is twofold one to get it in the correct orientation and the other to prevent it turning when you tighten the fastener.
Old 10-Jun-2012, 17:54   #4
Bikes: 1098s, 600ss
Hi Phil
Thanks for comin to the rescue again. Noticed the raised feature and the two holes just couldn't get my head round which way it went. Usual mechanical numptiness. And thanks Si but think the 620 is different.
At least if I get it wrong heat from the engine should keep me warm in the wet. See you at oulton guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:21.
