Old 14-Nov-2004, 20:16   #1
neil748r neil748r is offline
748RS wiring schematic?
Anybody got the wiring schematic for a 748RS?
Ideally need schematic, the positioning on the bike of all the components and the harness routing. Planning on making my own loom or possibly mod an OEM one (if that would be easier).
TIA, Neil.
Old 14-Nov-2004, 20:17   #2
yeti yeti is offline
yeti's Avatar
Neil, if anybody can help you here, Nelly at Cornerspeed can. But an RS is a bit of a rare beastie.
Old 14-Nov-2004, 23:44   #3
I may have a schematic in the PDF that Felix sent me.
The ECU mounts under the clocks as does a relay or two, the battery tray is about half the size of that found on a 916 and as well as holding the battery also mounts the Reg/rec, tilt switch and starter solinoid. The ON/OFF rocker swith mounts between the Rev counter and Temp gauge, the switch for swapping between oil and water temp eas on the right as was the start button, the kill switch was on the left bar.
No speedo, fuse box, lights etc
Old 15-Nov-2004, 13:41   #4
Thanks, that's exactly the kind of info I'm looking for.
So Felix has all this info then? I'll drop him a U2U, he's owe me a favour or two!
Cheers, Neil.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:40.
