Old 19-Nov-2004, 20:59   #1
keefer keefer is offline
keefer's Avatar
ohlins fork height ?
ok any one out there with some ohlins front forks.
I need to know where about they sit in the yoke
if any one could look and see how far down the top yoke they are please. Use the bottom of the top yoke please as its flat unlike the top. Thanks K
Old 19-Nov-2004, 21:05   #2
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Keefer, they normaly sit 4 rings down from the top face of the yoke at the lower level. That is the outter edge of the clamp section. But give or take a gnats nacker, shouldn't make much difference I would have thought.
Old 19-Nov-2004, 21:33   #3
keefer's Avatar
is the bottom ring level with the bottom of the yoke ?
Old 19-Nov-2004, 21:53   #4
Jon Jon is offline
Jon's Avatar
I didn't even look Keefer. 4 rings down to the top face of the top yoke.
It's std on all models and forks. Showa/ ohlins, not sure about ohlins R&T
[Edited on 19-11-2004 by Jon]
Old 19-Nov-2004, 22:51   #5
keefer's Avatar
ok thanks J
Old 19-Nov-2004, 23:02   #6
Ladybird Ladybird is offline
Mood: nearly brave enough..
Keefer, I run R&T's. From memory they run four rings, but I'll go and have a look tomorrow and get back to you. Might even be able to see it on the pics at www.jlawson.com/996
Old 19-Nov-2004, 23:03   #7
yeti yeti is offline
yeti's Avatar
That last post should have been logged as me, but herself has been muckin about again....
Old 20-Nov-2004, 11:36   #8
Top of the lower yoke, where the fork passes thru', to the top of the fork leg should be 244mm +/- 1mm.
Top of the fork leg is the spring cap, not the preload part.
When both legs are fitted, double check they are equal by laying a steel rule across the fork tops. You shouldn't see any daylight.
Old 20-Nov-2004, 12:57   #9
keefer's Avatar
all done thanks gents
Old 20-Nov-2004, 15:27   #10
yeti's Avatar
Ohlins R&T, three rings visible at rear of fork leg.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
