Old 16-Jun-2012, 14:00
pguenet pguenet is offline
FS - remaining 748 / 916 / 996 parts
I am putting much of the below on ebay, but if interested, please make offers.
Photos available in my photobucket available at:
http://s1177.photobucket.com/albums/...20Part%20sale/
748 Frame - £250
Frame is still on US title as previous owner did not bother registering it in the UK (used on a track bike). Import paper available. Frame powder coated in Ducati Red.
Frame numbers have been left showing as this is now scrutinized even at track days. Frame can be UK registered by going through the Motorbike Single Vehicle Approval. As the papers are available you would end up with the relevant year registration (and not a Q Plate).
Black powder coated Swingarm - £120
Recently powder coated.
Selling with hub, chain sliders, new bearings have been installed, front rubbers in place.
Additionally, choice of 2 axle with rear disc and choice of 2 caliper hangers
£40 for each axle / disc
£15 for each caliper hanger
Ohlins rear shock - £370
Standard ohlins rear shock with remote race preload adjuster. Makes the adjustment of the preload so much easier with a simple screwdriver.
Suspension rocker - £20
plain standard
Standard throttle bodies for 996 - £100
Standard bodies, 2 injectors per cylinder, standard loom for 996 with parallel firing of injectors as controlled by 1.6 ECU (should fit other models like 916 if you wish to upgrade to dual injectors). I can throw the manifolds in with these.
Standard throttle bodies and airbox for 999 - £120
just standard
748 R throttle bodies bored to 54mm with spacers for fitment to 996 as performance upgrade - £250
This will allow performance upgrade with shower injectors to 996 engine. Note - you will need the bigger airbox with injectors inside the airbox for this set up.
Coils + leads to spark plugs - £40
Pair of standard coils with brackets for 916 / 996 with HT lead to spark plugs.
Pair of Sil Motor race slip on exhaust. - £170 - SOLD
Nice open carbon pipes, look better in my opinion than Termis due to having shorter pipe ends. Sound pretty good too.
Rest of the 45mm system also available for £50 (quite clean) first refusal to whoever buys the end mufleurs.
Standard 916 tank - £120
Bare tank - clean as can be seen in pictures. Couple of paint blemishes but otherwise OK. No pump.
Magneti Marelli 1.6 ECU for 916 - £40
Eprom was supplied by Louigi moto for 916 with open 50mm system.
Titanium front axle - £80
Will fit the 748 / 916 / 996 / 998 series as well as STs, some Monsters, etc.
998 oil cooler - £30
Old 16-Jun-2012, 14:06
Old 20-Jun-2012, 20:18
Quick update:
748 Frame - £250 - available
Pierobon front subframe - sold
Black powder coated Swingarm - £120 - available
axle / disc £40 - drilled one gone other available
Caliper hanger £15 each - available
RS Caliper hanger - sold
Ohlins rear shock - £370 - available
Suspension rocker - £20 - available
Standard throttle bodies for 996 - sold
Standard throttle bodies and airbox for 999 - £120 - available
748 R throttle bodies bored to 54mm with spacers for fitment to 996 as performance upgrade - £250 - available
Pair of Sil Motor race slip on exhaust. - Sold
45mm system clean £50 - available
Standard 916 tank - £120ono available
Magneti Marelli 1.6 ECU for 916 - £40 - sold
Titanium front axle - £80 - sold
998 oil cooler - £30 - available
Old 06-Aug-2012, 21:48
Toospeed Toospeed is offline
Bikes: 748 RS
Do you have some pics of the 998 oil cooler? thx
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:08.
