Old 21-Nov-2004, 23:37   #1
sidestand cutout
currently converting the 749s to a full blown track tool for next year
After trashing my current track bodywork at Rocky I'm on the lookout for some new plastics. I want to fit bodywork with an oil cathing belly pan etc - without a sidestand ( kept grinding the back of my sidestand at Mansfield all last year). Thing is the bike features an interlock that cuts the engine if you select a gear with the sidestand down. If I just remove the sidestand with its switch will the bike run in gear or do I need to fiddle with the wiring?
I know the obvious answer is try it but the bike is without wheels on stands with no tank / fuel pump etc. fitted at present.
Should have thought about this earlier!!
Any help appreciated!!
Old 22-Nov-2004, 00:24   #2
Ive sent you a u2u, just unbolt the switch from the sidestand when the stand is up, re connect it to the wiring leaving the rotational switch in the 'up' position.
Old 22-Nov-2004, 07:39   #3
And put a cable tie through it to stop it rotating back down.
Old 22-Nov-2004, 11:17   #4
cheers both!
ah - the joys of winter fiddlin'
