Old 22-Nov-2004, 18:55   #1
Rocker Rocker is offline
Mood: Happy again with Numptystrada
Aircraft Humour
> Subject: Aircraft Humor
> After every flight, pilots fill out a form called a gripe sheet, which
> conveys to the mechanics problems encountered with the aircraft during
> the flight
> that need repair or correction. The mechanics read and correct the
> problem, and
> then respond in writing on the lower half of the form what remedial
> action
> was taken, and the pilot reviews the gripe sheets before the next
> flight.
> Never let it be said that ground crews and engineers lack a sense of
> humor!
> Here are some actual logged maintenance complaints and problems as
> submitted by Qantas pilots and the solution recorded by maintenance
engineers (By the way, Qantas is the only major airline that has never had
an accident.
> (P = The problem logged by the pilot.)
> (S = The solution and action taken by the engineers.)
> P: Left inside main tire almost needs replacement.
> S: Almost replaced left inside main tire.
> P: Test flight OK, except auto-land very rough.
> S: Auto-land not installed on this aircraft.
> P: Something loose in cockpit.
> S: Something tightened in cockpit.
> P: Dead bugs on windshield.
> S: Live bugs on back-order.
> P: Evidence of leak on right main landing gear.
> S: Evidence removed.
> P: DME volume unbelievably loud. (Distance Measuring equipment)
> S: DME volume set to more believable level.
> P: Friction locks cause throttle levers to stick.
> S: That's what they're there for.
> P: IFF inoperative.
> S: IFF always inoperative in OFF mode.
> P: Suspected crack in windshield.
> S: Suspect you're right.
> P: Number 3 engine missing.
> S: Engine found on right wing after brief search.
> P: Aircraft handles funny.
> S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
> P: Noise coming from under instrument panel. Sounds like a midget
> pounding on something with a hammer.
> S: Took hammer away from midget.
Old 22-Nov-2004, 18:59   #2
It's old.... but an absolute classic
Old 22-Nov-2004, 19:07   #3
I hadn't seen it before However if it is that old maybe some of our members are too young to have seen it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:48.
