General Motorcycles only
Old 25-Nov-2004, 14:06   #1
Fuel stabiliser which one...any recommendations ????
Or is any well-know brand as good as each other???
ANy chance of flying the flag with a British firm???
Silkolene or Castrol ???
Cheers - Frank
Old 25-Nov-2004, 14:19   #2
phil_h phil_h is offline
phil_h's Avatar
I don't think there will be any difference in performance between brands.
If you are laying up for the winter, just remember to run the bike after adding it to the fuel so it gets into your injectors !
Having talked to louigi about the amount of hassle cleaning gummed injectors, fuel stabiliser sounds like a very good idea !
Old 25-Nov-2004, 16:34   #3
keefer keefer is offline
keefer's Avatar
I saw someone ask about this in the post winter storage the other day ?.
Why would anyone want to put a fuel stabilizer in that cost good money when you can just drain out the old fuel and put it in the car. Then when you want to use it, you go get some fresh fuel from the petrol station and Bobs your uncle away you go
Old 25-Nov-2004, 19:02   #4
Petrol keeps easily for three months anyhow. Not that easy for some to drain it out, i couldnt be bothered to do it for example. You need to get the whole system bone dry for it to be worth doing any how.
Old 25-Nov-2004, 22:35   #5
sparkin sparkin is offline
sparkin's Avatar
|I used motorex a year or two back and that was fine,prevented corrosion in the tank and started on the button four months later
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:47.
