Old 26-Nov-2004, 22:57   #1
custard custard is offline
Mood: yes mistress
oil breather
I have just seen on the web, a crank case breather for a 748, 916 996 998. It say's that it inproves performance, but also say's "for track use only". Why is this, why can't it be used on the road?.
Old 27-Nov-2004, 16:57   #2
The oil vapors from the sump are piped back to the air intake to be burned instead of being vented to the atmosphere as air polution. So it's illegal to run the device you're talking about.
The theory for the best crankcase ventilation says that you loose less horsepower through pumping losses if you vent to a large volume. That's why the aftermarket setups initially looks attractive. But if you vent to an airbox vacuum, there are fewer losses than if you vent to a larger volume at atmospheric pressure. This stock system has the added benefit of a collection/separation tank between the crankcase and the airbox.
The following is a post by BCM Ducati, a top Ducati tuner here in the States:
What is different about Ducati streetbike breathers in general is that the reed valve is mounted directly in the case. The breather box location and volume are good.
The reed valve location is good for emissions but not for engine power and crankcase breathing. What happens is that under certain conditions, under high rpm and light load, the oil doesn't run back because of the reed valve and it builds up in the tube above the reed.
The simplest solution is to hollow out the reed assembly and leave it internally open but still hitched to the volume bottle. This allows the volume of the breather bottle to perform its function and usually gives a slight horsepower increase also.
Then, use either a 748RS reed valve in the airbox at the end of the breather hose, OR, use a Ford diverter valve (in-line one way) just before the airbox.
Never use an external atmosphere vented breather. It's a horsepower loss and you're asking for trouble as even the little filters don't stop the dirt from getting back into your engine.
Removing the volume bottle hurts peak horsepower slightly and doesn't allow a place for the air and oil to separate so that the oil can run back into your engine.
Run the oil level smack in the middle of the sight glass and never any higher. If you look at most superbikes, no matter what manufacturer, their crankcase ventilation systems are similar to what I've described. Even the Ducati Corse bikes are setup this way, only the street bikes which have to meet strict emissions requirements, are setup the other way.
We have successfully run this setup on Ducatis up to 1100cc with no issues.
[Edited on 11-27-2004 by Shazaam!]
Old 27-Nov-2004, 21:50   #3
Maybe illegal in the States but i dont think it is over here.
Old 27-Nov-2004, 22:51   #4
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
It doesn't comply with the homologation of the bike when new, but as soon as it rolls off the forecourt, as long as the oil vapours are not going to condense in such a way as to cause danger to the rider ( by going all over the back of the bike ) or other road users ( by pouring all over the road ) then it's totally legal in the UK.
Andy
Old 27-Nov-2004, 23:43   #5
There's no hydrocarbon emission regulation in the UK?
Old 28-Nov-2004, 01:14   #6
Rushjob's Avatar
Mood: :-)
Yes - but they are only concerned with what comes out of the exhaust system....
I don't believe it...... the UK is almost sensible - I must be dreaming!
[Edited on 28-11-2004 by Rushjob]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
