Old 07-Dec-2004, 23:49   #1
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Funny Noises
Just today I've noticed an odd noise with my '99 750ss. Here's the scenario:
- My bike had been standing for about 4 days. Last time I rode it was last Thursday evening.
- This morning the battery was nearly dead. Bike would turn over but not fire. I needed to roll start it.
- On the way to work started to notice an odd "noise". The only way I can describe it is a "clack" and a "hiss".
- On the way home from work this evening the noise started getting lowder.
- Noticed the bike felt to be underpowered on the ride home this evening
- Noticed that on the overrun, when using the engine for breaking down through the gears, that there were a lot of "pops" like mini backfires. This has sometimes happened in the past, but not constantly.
- At idle the noise is not appreciable, but anything about 2k revs it is noticeable.
I had a bit of a look around the bike when I got home tonight. It's a half faired version so access to the engine is easy enough. I couldn't see much really.
I know it's not much of a description, but any ideas?
Just booked a service today so it'll get sorted out in a couple of weeks. But am I terminal? Should I be riding it at all over the next couple of weeks?
Thoughts appreciated.
Phill
Old 08-Dec-2004, 00:07   #2
Working on the 'hiss' and loss of power descriptions I'd be looking around:
loose cylinder bolts
loose carb mountings
loose exhaust rings
as a starter.
I'm sure Nelly / someone much more knowledgeable will be along shortly!
Good Luck - Frank
Old 08-Dec-2004, 00:10   #3
Thanks for the hints Frank!
It's actually Nelly that I phoned earlier today to book the bike in for a service, so I'm sure it'll get sorted then. To be honest when I phoned earlier to book the service I didn't think much of the noise and hence didn't ask about it. I was half asleep riding to work this morning so it didn't register much - and I was annoyed about having to roll start it.
I think we can discard your "carbs" theory as I have an injection version.
One of the other two perhaps though......
Old 08-Dec-2004, 00:51   #4
all Franks suggestions could be valid. replace carb mounts for inlet manifolds.............
Only other thing that springs to mind is the tank breather?? Petrol starvation under load? weak running on over run etc. The cap was cleaned when the tank was swapped after imploding, could be something??
Is the fuel low? does it get any better on a full tank? Try lifting the filler cap after a run and listen for a "sharp intake of breath".
Old 08-Dec-2004, 00:55   #5
Nice one Nelly, thanks.
I'll definetely open the tank cap tomorrow morning after riding to work and see what happens and I'll check the overflow pipe for blockages.
I'd be a v. unhappy camper should my tank implode again. Infact I'm tempted to go out in the cold right now to open the cap to ensure it doesn't crumple overnight........
Phill
Old 08-Dec-2004, 00:56   #6
Phill
does it get "cold" down there then LOL
Old 08-Dec-2004, 01:00   #7
For an Australian, yes.........
[Edited on 8-12-2004 by phillc]
Old 08-Dec-2004, 01:10   #8
BE VERY CAREFUL THE AREA IS TOTALLY VENTED OR YOU MOVE THE BIKE WELL AWAY FROM ITS STORAGE AREA BEFORE STARTING.
GASEOUS PETROL IS NOT TO BE UNDERESTIMATED !!!!!!!!!!!!!!!!!!!!!!!!!
**** PLEASE BE CAREFUL - IF LEAVING TANK VENTED - OK ****
Old 08-Dec-2004, 01:11   #9
Can't help you the rest mate but if you want to borrow my optimate for a bit you're more than welcome. Give that battery a charge up.
Let me know.
Cheers,
TP
Old 08-Dec-2004, 21:26   #10
Thanks for the warning Frank. In the end I didn't leave the tank vented overnight, just opened and closed it to make sure there was no build up of pressure.
Anyway, I think I've got this figured out.
There appears to be exhaust gases escaping from the exhaust manifold (that's what you call the bit where the exhaust joins with the rest of the engine right?). The noise kept getting worse, so I had a good close look this afternoon. Before everything got to hot, I could put my hand around the manifold and feel gases escaping from there.
This would explain:
a) The noise
b) The loss in power
c) The constant popping on overrun as air got in
So my next question is:
- What do you think has happened? I'm hoping someone knowledgeable will say that it's most likely just a seal blown.
- Will I damage anything if I keep riding like this? Service due in a couple of weeks, I can put up with the noise that long, but am I likely to do any lasting damage to the engine?
Phill
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
