Old 30-Jun-2012, 18:01   #1
Steve E Steve E is offline
DS1000 battery not charging
Hi All,
Just got back home by AA Relay. My Sport 1000 died for the second time this week on a country lane. It has a new battery but its not charging so I guess a new or re-conditioned alternator is in order. Anyone have any ideas on the possible work involved and cost? Is there anything else apart from the alternator that could have failed? I'm not sure weather to go to the nearest Ducati dealer or have a go myself.
BTW the engine is the DS1000 as used on the Monster etc. Its a 2006 model.
Any feedback or advice most appreciated.
Steve
Old 30-Jun-2012, 18:32   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
This article tells you how to test the reg/rec and the stator to diagnose which has failed (It's from a Triumph site but is still applicable)
http://www.triumph675.net/forum/showthread.php?t=35227
Old 30-Jun-2012, 19:08   #3
First step, check the charging Fuse
If its not that then Check the Alternator connector , the 3-way connector that joins the 3 yellow wires coming from the alternator casing to the 3 yellow wires coming from the Regulator/rectifier, this is also the connector you pull apart to check the AC volts coming from the alternator when the engine is running
Old 30-Jun-2012, 23:11   #4
Chris, Skidlids,
thanks very much, I will have a look tomorrow. Fingers crossed. I will let you know how I get on.
Steve
Old 01-Jul-2012, 20:05   #5
Yep, most likely the reg/rec and very easy to swap out if you want a hand!
Old 01-Jul-2012, 21:18   #6
chrisw's Avatar
Might be time for an upgrade.
http://www.ducati-upnorth.com/forum/...mod&highlight=
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:39.
