Old 12-Dec-2004, 01:39   #1
998BP wiring Diagram WANTED
Anybody got a wiring diagram for a 998BP I could borrow/make a copy of.
Kev
Old 12-Dec-2004, 09:59   #2
psychlist's Avatar
Mood: Lucky? For some, maybe!
You can have a look at my handbook and see if thats what you need kev, I'll copy it at work and send it on then!
See you at Popham
Old 12-Dec-2004, 11:03   #3
Cheers Paul
See you at Popham in a few hours :]
Old 12-Dec-2004, 11:08   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
I have the PDF's of the US and UK owners manuals but the loom info is not included, sorry. Lots of others, does it have to be a 998?
Old 12-Dec-2004, 11:35   #5
It appears so Rob, I have a lot of the PDF's but none have the 998 wiring. where the bike uses the 5.9M ECU they look as if they have altered some other parts of the wiring in the large screw together plug just above the battery. Not only is the front loom up to the headlight longer it is also wired different to the eariler models.
As a 998 front harness is as rare as Hens teeth on the second-hand market I hope to use two earler harnesses spliced together.
Its about time I had the bike up and running so I can get on with my next project and also try and get a Desmo Due racer sorted.
Kev
Old 12-Dec-2004, 14:27   #6
Mood: aving a laff
just checking my stuff Kev.
Will send you an email if i can find one.
Old 12-Dec-2004, 16:17   #7
Mood: aving a laff
Wiring diagram
Old 12-Dec-2004, 16:20   #8
Mood: aving a laff
key to diagram
Old 12-Dec-2004, 22:09   #9
Cheers Geoff, I will try and get them printed out at work tomorrow and see how I get on from there.
Kev
Old 13-Dec-2004, 09:04   #10
psychlist's Avatar
Hah! Guess my snail mail isn't good enuff then
