Old 27-Jun-2003, 19:47   #1
Steve Steve is offline
Fitting open DP Carbon clutch cover
I'm trying to fit the DP carbon clutch cover to my 748, however there isn't enough space between the cover and the clutch, so the clutch rubs on the inside of the cover. Does the cover require any sort of spacers?
Please help
Old 27-Jun-2003, 20:24   #2
neil748r neil748r is offline
Steve, you need to pack it up with some washers approx 5mm in total should do it.
The latest type (assuming it's DP) come with this pre-done. Kinda carbon post things moulded as part of the cover. Maybe take it back and swap for latest type?
Old 28-Jun-2003, 19:50   #3
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
You could always try to use the std rubber gasket that comes with the std clutch cover ?
Jon
Old 28-Jun-2003, 21:37   #4
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Nigel Booker's Avatar
The std rubber gasket comes with spacers, just push these out and put thenm between the clutch housing and the new dp carbon cover.
Old 28-Jun-2003, 22:47   #5
ducatimad ducatimad is offline
I\'m getting anumb right foot!!
After fitting DP rearsets and an open clutch cover (don't you just love that noise) I am suffering from a numb right foot after about 30 minutes. Any suggestions?
Old 28-Jun-2003, 22:57   #6
Jon Jon is offline
Jon's Avatar
DM, I don't think it's the open clutch cover, unless your toe's are getting stuck between the grilles Suggest you try altering rear sets so that ankles,feet or what ever that is bent too far and restricting circulation.
Jon
Old 29-Jun-2003, 16:05   #7
RE: Numb feet.
Think I read somewhere that the numb feet thing is down to the footpegs on the DP rearsets being solidly mounted and therefore transmiting general vibes to your feet.
Old 30-Jun-2003, 00:32   #8
Totto Totto is offline
I found that i get more vibes after fitting rearsets , keep the chain lubbed it helps ,never used to lub it much but do now !
Old 30-Jun-2003, 00:55   #9
Mood: aving a laff
Ducatimad
Try stopping a bit more often?
Like every twenty five minutes?
Have DP rear sets on mine and dont find much difference than standard but never seem to be in the same position for long anyway.
Follow the previous advice if you cant get used to the vibes.
You never mentioned if you ride on your bridges or the balls of your feet?
I always ride on the balls so this might help as it is a bit softer than the bridge section of my boots?
Hope you sort it out, if you do then post your methods as others might have the same problem?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:34.
