Old 28-Jun-2003, 20:10   #1
istanbulian istanbulian is offline
Mood: Mellow but missing Turkiye
Mudguard & tailunit
OK guys, what is the secret to not losing the mudguard and licence plate ?
3 weeks in a row now I have lost bolts, plates and today the whole ******* unit. Is it just me or is this weakpoint in the desgn when faced with ROUGH roads ?
...and to think I sold the Superblackbird because it was too reliable and uninvolving !
Not giving up...just venting
[Edited on 28-6-2003 by istanbulian]
Old 28-Jun-2003, 20:22   #2
adam adam is offline
Mood: happy
try using locktite on the bolts.
Old 28-Jun-2003, 21:38   #3
Felix Felix is offline
The bolts screw into wellnuts (nut in rubber grommet). If you use loktite, you will never get them apart again because the wellnuts will simply rotate. Are the wellnuts still there after you've lost the mudguard/plate holder?
Tighten them up more.
Old 28-Jun-2003, 22:13   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Istanbulian. Seems to me that your bike might have been track day'd. I know that when I came to change the numberplate holder for one of Cornerspeed's brilliant relocator one's they were has tight has a witch's c#^t. It was the first time it had ever been off.
[Edited on 28-6-2003 by Jon]
Old 29-Jun-2003, 07:31   #5
Thinks its time to buy whole new set of the wellnuts as this time the bolts came out with the metal inserts of the wellnuts still attached...leaving just the rubber inserts in the frame ! The only thing I can think I did wrong this time was that they were actuallt too tight ?
...there again may ditch the wellnuts and just go to conventional bolts with rubber grommets
is the cornerspeed relocator the same as that offered by Evoluzione ?
[Edited on 29-6-2003 by istanbulian]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:46.
