Old 23-Dec-2004, 17:02   #1
cashburning748r cashburning748r is offline
Mood: For Sale...
WD40
Great stuff until it gets on your brake discs.
Any cures as i'm running out of patience trying to scrub it off in motion. Bit fed up as the bike has just come back from a service and it wasnt picked up along with a whole host of other missing work. I guess this is what happens when you have to find a new service provider when your local one closes.
Brakes are biggest prob so answers on a postcard... take them off and scrub them?
Old 23-Dec-2004, 17:07   #2
Mr_S Mr_S is offline
Ditch your pads, they'll have been soaked in it by now and your biggest problem.
For the disks, I'd try cellulose thinners / acetone / tar remover, then finish with some fine steel wool.
but change the pads at the same time.
Old 23-Dec-2004, 17:08   #3
chris_of_1979 chris_of_1979 is offline
Mood: I'm Bad!
I'd think about taking them off, wipe them thouroughly with a CLEAN rag soaked in white spirit, then leave to dry/evaporate. Then wash off with plenty of water and leave to dry again.
Then re-fit them making sure new pads go in at the same time (the old one's will be contaminated).
Others might have a better idea though???
Old 23-Dec-2004, 17:11   #4
yeti yeti is offline
yeti's Avatar
You've naffed up your pads CB, as Mr S pointed out they will have soaked up the oil, however if they are sintered pads, the oil may not have penetrated the pad material very far so you could remove the top layer and get down to fresh pad material.
I did this when my Ohlins blew a seal and sprayed fork oil all over the discs and calipers, nearly crashed, but that's another story. The pads were well soaked so I put them in the milling machine at work and skimmed about a mm off the top surface. Did the trick.
If you can be without your pads for a week or so, drop me a U2U and you can send them up and I'll skim em for you. Unfortunately this won;t now be till we get back after xmas hols tho'
Brake cleaner (inhibited trichlorethelyn) will clean the discs.
[Edited on 23-12-2004 by yeti]
Old 23-Dec-2004, 17:12   #5
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
been there... dun that...
as said, new pads and clean the discs. Just a wipe with some brake cleaner was enough.
Old 23-Dec-2004, 17:13   #6
The actual lubricant in WD40 is very light so if the pads are ruined they must have used a huge amount of it!
Use meths or brake cleaner to clean the disks.
Old 23-Dec-2004, 17:13   #7
Simon Reed's Avatar
Mood: Cool as **** !
Do not use white spirit as thats oil based !!! brake/carb cleaner is the only answer,but if i were you m8,i'd put new ones in,it ain't worth the risk is it ???
Old 23-Dec-2004, 17:34   #8
Mood: For Sale...
Guys, thanks for the responses.
Special thanks to Yeti for the kind offer of a skim but I think im going to plum for new pads.
It's my own fault, after a good day out I chose to coat the bike in the stuff opposed to leaving it all night, sadly, i did this in the dark which restricted accuracy somewhat.
It wouldnt be a 'cashburning748' if I wasnt spending money on it... damn.
Any ideas for a mail order service? or flexible openig hours over xmas.
Seasons greetings, take care all.
Mark
Old 23-Dec-2004, 17:56   #9
Ray Ray is offline
Ray's Avatar
CBR,
Brake cleaner will do the job. Like others have said unless you have soaked the pads in WD40 don't worry too much
I have got a bit of WD on brakes before and I'm still alive.
WD40 or similar in small amounts will soon burn off as the the majority of the liquid will evaporate.
Just take it very easy and see how the brakes are before nailing them outbraking the Novas into your local roundabout!!
Ray
[Edited on 23-12-2004 by Ray]
Old 23-Dec-2004, 18:26   #10
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
I see a number of posts about WD40 ruining Ohlins. I assume this is the oil doing the seal in bit??? Or is there someting in WD that attacks the finish that I don't know about (yet)
TIA, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
