Old 27-Dec-2004, 10:44   #1
pcn1 pcn1 is offline
pcn1's Avatar
TPS adjustment
I'm almost ready to have a go at setting up the TPS and balance out the throttle bodies. Will I need to drop the complete fairing ? I read somewhere that you take of the air box, if true would this not effect the throttle balance when put back ?
Old 27-Dec-2004, 18:51   #2
Why should it affect the balance, it just sits on top of the throttle bodies. Bit of a bugger to get back on though, took me nearly two hours!!
Whats the bike?
I did my ST2 years ago and i took the airbok off to get access to the balance screw. Not sure if its the same on the ST4 and 4S.
You will need to take enough of the fairing off so you can get at the throttle bodies which in theory means both side panels but in reality means the whole fairing beacuse you can't get the sides off without taking off the nose fairing and the belly pan.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:48.
