Old 27-Dec-2004, 16:42   #1
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
748 Bip sprocket change
I have done a search of the forum and I am a little confused.
It is time to change the chain on my 1998 748 Biposto, so I am taking the opportunity to maybe change the sprockets also.
What are the standard factory sprocket tooth sizes?
Why should I change to a higher or lower tooth spec?
Any advice on what chain to purchase?
Old 28-Dec-2004, 16:21   #2
All stock 748's have a 14-tooth front sprocket, which is the smallest practical size. In the US, a stock 748 comes stock with 38-tooth rear sprocket that is too high, most will agree.
Probably the most popular gearing change for this model - for street use - is to a 41-tooth rear. Talon, Renthal or AFAM sprockets are popular.
A 38-tooth rear uses a 94-link chain. If you change to a 40, 41, or 42 rear sprocket, you will need a 96-link chain.
748's use a 520 chain size supplied by DID. Tsubaki chains are well made - as are AFAM Regina, DID, RK, and EK chains. AFAM chains are made by DID.
Ducati uses a eccentric to adjust the chain tension so remember to measure your rear ride height BEFORE you change your rear sprocket so you can later raise your ride height back to where it was after the change.
Old 29-Dec-2004, 12:37   #3
PDL PDL is offline
PDL's Avatar
Shazaam! - Thank you for the info. I think i will change to a 41 rear.
What differences in performance will i see?
Old 29-Dec-2004, 12:42   #4
Bionicle Bionicle is offline
Bionicle's Avatar
Better acceleration through the gears, but about -5 MPH off the top end
Old 29-Dec-2004, 12:55   #5
PDL PDL is offline
PDL's Avatar
Bionicle - thank you
As i have never had the bike flat out I am not going to miss what I have never had. (Angelina Jolly etc) So it is a 41 tooth for me then.
cheers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:57.
