Old 03-Jan-2005, 18:11   #1
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
AAAAAaaaaaarrrggghhhh Another Nail!!!!!
Found another nail in my rear diablo this morning must be about 1.5" long gone right it not lost any air only done about 2000m so hope fully get a permanent plug done
I expect its been asked before but are the plugs that good is it worth the risk? is there a risk?
Old 03-Jan-2005, 18:19   #2
keefer keefer is offline
keefer's Avatar
used them b4. as long as its in the centre of the tyre you shouldn't have any probs.
Old 03-Jan-2005, 18:47   #3
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
most tyre fitters i've spoken with have said they won't plug ZR tyres, but I've had one done with no probs.
but 2000m from a tyre... lucky you!
Old 03-Jan-2005, 19:06   #4
Bikes: Xdaivel
Lee1980's Avatar
Thanks Keefer its off the one side but no where near the edge, see the pic.
Its a standard Diablo Nick so lasts well as can be seen by the tread left
Had the evo corsa replaced after only 2000m after it couldn't be plugged due to having 2 holes close together
[Edited on 3-1-2005 by Lee1980]
Old 03-Jan-2005, 19:09   #5
keefer's Avatar
o yea
should be able to get that done no probs
Old 03-Jan-2005, 19:21   #6
Bikes: Xdaivel
Lee1980's Avatar
Thanks Keef
I pushed the nail back in and it hasn't lost any pressure just take a slow ride to protyre
Think he said it would 20-25 last time if he can plug or 106 for a new diablo
Old 03-Jan-2005, 19:37   #7
This topic comes up often with the obligatory dire warnings. So ask yourself ...
How is the safety risk of a leak from a repaired tire any different than the risk of a puncture in the first place? The consequences are the same. The overall risk of injury is also the same. The failure probability of a properly repaired tire from all accounts is no greater than the chance of running over a nail in the first place.
So, if you're going to get squeamish, you should probably do so BEFORE you get on a motorcycle.
We live in an age where everyone sues anyone for anything ... so no wonder it’s hard to get a tire manufacturer or a repair shop to get past the liability issue to agree to patch a freakin’ tire. Our grandfathers would be amused (and also a bit ashamed) at us throwing away a perfectly good tire because it got a puncture. So, if you can’t get a dealer or tire shop to dismount the tire and properly patch it from the inside, then buy a kit and do it yourself.
Keep in mind that a tire manufacturer is in the business to sell tires so there's really no reason for them to suggest patching a puncture. However, Dunlop (to their credit) offers this advice:
"Dunlop recommends only permanent repairs performed from the inside of the tire, using a combination patch/plug method. Never attempt a repair from the outside, or inject a sealant, or simply use an inner tube, a patch or a plug as a substitute for a proper repair. Only a qualified tire repair shop or motorcycle tire dealer should perform repairs. Inspection of the tire and adequacy of repair becomes the responsibility of the person actually performing the repair and Dunlop does not warrant the results of a repair in any way."
That just about covers their butt, but there IS a point to be made here ...
You need to use a proper repair kit and materials, and only on tires suitable for repair. If you're going to do the repair, then YOU have to remove the tire from the wheel and do the inspection yourself. Here's some guidelines for either you or the tire repair shop:
The tire should NOT be repaired if:
• The puncture is larger than 1/4-inch in diameter
• The puncture is not perpendicular to the carcass
• The puncture is in the tire sidewall.
• There are any cut or separated plies
• There is any bead or carcass damage from running the tire flat
• The tire has been previously injected with a sealant/balancer
• There is more than one repair in any quadrant of the tire or there were two prior repairs to the tire.
Old 03-Jan-2005, 20:57   #8
clockwork orange's Avatar
Mood: On top of the world
I recall some years ago (ok, more than some) having a puncture repaired with a plug on a light LDV rear tyre. Vehicle rated to half ton, and was carrying a load of 495kg at the time. Ran at 120km/hr for 600 km with no trouble at all.
Guidelines above seem about right, ie apply some of that uncommon thing called common-sense....
Old 03-Jan-2005, 21:24   #9
Bikes: Xdaivel
Lee1980's Avatar
Thanks Shazamm, what u say is true probably be no less safer than before
the nail is less than a 1/4 in dia. so should be ok and has gone straight in, will see tommorow
Old 03-Jan-2005, 21:41   #10
GsxrAge GsxrAge is offline
GsxrAge's Avatar
A top man in micheln wrote into MCN the other day to say it was safe to plug there zr rated tyres and could not understand why tyre fitters would not repair them.
Perhaps it's because they make more money on new tyres
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:38.
