Old 04-Jan-2005, 11:27   #1
Frank Frank is offline
Mood: got to be a worry.....!
Extra bracket on termi\'s
happy new year to you all and hope Santa did us all proud!
over the holidays I started to fit my 45mm termi's and noticed on the right pipe there are two brackets with threads which are not on my stock pipes, any ideas what I am supposed to attach? too high for footrest so am presuming a heat shield of some sort but why do I need one for these cans and where do I get them if I do actully need one?
Old 04-Jan-2005, 11:48   #2
Must be mounting point for the SPS style heat guard - the L-shaped one rather than the square one that mounts on the central link pipe?
Old 07-Jan-2005, 13:32   #3
Godders Godders is offline
Mood: Praying for a long dry 2005
antonye is absolutely right, made the same conversion myself recently - make sure you get the correct shield as there seem to be a couple of different sizes (I measured the distance between the threads to make sure I got the right one) Also don't forget the chip for the ECU and then setting up afterwards. Worth the work just for the sound!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
