Old 04-Jan-2005, 19:16   #1
uncle porry uncle porry is offline
uncle porry's Avatar
Engine life ?
anyone know the approx miles a standard (regular seviced) 748 lump should do before major rebuild....?
cheers
Old 04-Jan-2005, 21:08   #2
I've got a customer with a 748SPS that has at least 50000 kilometers on the clock now and it's still going strong.
Old 04-Jan-2005, 21:42   #3
Mood: childish
ooer unc this sounds serious or do you have a bit of spare time to kill
Old 04-Jan-2005, 22:58   #4
moto748 moto748 is offline
My 748's done 41000 miles now, in 3 years.
What do you mean by "major"? To be honest, I don't see why it shouldn't run as long as any other motorcycle engine, as long as regularly serviced etc.
Apart from consumables like rectifiers and clutches (actually not *that* bad on that score), nothing's really gone wrong. The rockers were pulled at the last major service. One was replaced; all the others were fine. I was told that the cams still had the parkerising coating fully intact on them. On that basis, I don't imagine there's any serious engine wear to the bores, etc. Certainly it uses only a negligible amount of oil.
Of course, it's yellow, so that probably explains my relative lack of problems.
Old 04-Jan-2005, 23:33   #5
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Just keep the throttle pined to the stop and tell us when it goes BANG
Old 05-Jan-2005, 10:01   #6
DAVE HARRIS DAVE HARRIS is offline
My old 1998 916 has done around 30,000 miles, the use has been track days blasts to assen commuting. At the last service I had the cams pulled and the rockers and cams were perfect only a couple of shims needed replacement and the compresion was the same as at the 500 mile service.
I have a major service (inc belts every year and only use top quality oil. the only wear you notice when riding it is a slight clonk over bumps which is the fork bushes.
If the botom end goes next week I would still think the engine had lasted well.
dave
Old 05-Jan-2005, 18:25   #7
no worries mate, she`s running fine, just wondered as i plan on keepng my duke for a long time......thanks all, for the info.....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
