Old 07-Jan-2005, 12:21   #1
FS Ebay - ND PLATINUM SPARK PLUGS FOR DUCATI 600SS
4 off for £14.99 is not bad if the bid stays there.....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...5776 230&rd=1
Old 07-Jan-2005, 15:33   #2
Platinum and Iridium Sparkplugs
Regarding the use of platinum and iridium spark plugs in a Ducati:
Platinum or iridium plugs will give you worse performance than a conventional plug unless you use a larger gap than is recommended for the steel electrode plug equivalent. One by-product (and benefit) to having platinum or iridium as an electrode material is that the harder material erodes more slowly and consequently allows you to reduce the size of the center electrode and still have a long-lifetime plug. Re-gapping is infrequent or eliminated. In fact, the initial reason this type of plug was developed was an attempt to meet the 100,000-mile durability/maintenance requirement mandated by the US EPA for exhaust emissions, not because they offered any improved performance over conventional electrodes.
A smaller electrode, however, will arc at a lower voltage. This is good because the lower arc-over voltage is not as demanding on your less-than-new ignition coils and wires so the firing is more reliable. But this is also bad because a lower arc-over voltage presents a weaker spark kernel (lower arc current and duration) that is less likely to light off the air/fuel mixture.
Consequently, dyno testing shows a performance gain with specialty plugs only when their intrinsically lower arc-over voltage has allowed users to increase the plug gap above that possible with conventional steel electrode plugs. A larger plug gap needs a higher arc-over voltage to fire, and a larger gap, combined with good plug wires and coils, will span more fuel molecules resulting in a more reliable burn with fewer misfires.
So you get better throttle response. Not more power mind you, better throttle response.
Conversely, I have seen several examples of Ducati throttle response problems cured by replacing platinum/iridium plugs that were gapped too small (i.e. the 0.024 in. Ducati recommends for conventional plugs.) Both NGK and Denso pre-gap their Ducati application specialty plugs to 0.035 in. This should be considered a minimum gap for this kind of plug.
If you have a older bike, you may arc-over the plug wires before you can fire an optimized larger plug gap. If the spark plug wires have inadequate insulation, the wire cannot maintain a high enough voltage across the insulation and will arc to ground before firing the plug gap. The factory spark plug leads are stranded wire covered with an EPDM jacket and although the wire itself will last a long time, the insulating jacket will start to break down after a couple of years which is why most good aftermarket wire is insulated with silicone.
If this becomes a problem, replace the stock spark plug wires with a set of Magnecore or similar quality wires. This will allow running a larger plug gap without a concern for insulating the higher voltage needed to jump the gap. Ducati Superbike Magnecore #2549 wires, for example, run $67.
For street bikes, you should use carbon core wires, preferably carbon wires with a spiral wrap center conductor. Straight, multi-stranded, unshielded wire conductors offer theoretical gains resistance-wise, but produce lots of electromagnetic interference (EMI). One major concern is with the computer found used on fuel injected bikes since the radiated EMI can interfere with the computer and corrupt sensor and internal signals which can affect engine performance and reliability. This concern also extends to the use of non-resistor type spark plugs.
For older Super Sport bikes, Dynacoil replacement coils are also available and a recommended upgrade.
Old 07-Jan-2005, 16:20   #3
FiscusFish's Avatar
......For street bikes, you should use carbon core wires, preferably carbon wires with a spiral wrap center conductor. Straight, multi-stranded, unshielded wire conductors offer theoretical gains resistance-wise, but produce lots of electromagnetic interference (EMI). One major concern is with the computer found used on fuel injected bikes since the radiated EMI can interfere with the computer and corrupt sensor and internal signals which can affect engine performance and reliability. This concern also extends to the use of non-resistor type spark plugs......
So p'raps if all the carbed racers used these unshielded plug leads the fuel injected boys (girls?) would all suffer terminal miss-fires...? A plan perhaps....?
Darren
Old 08-Jan-2005, 02:03   #4
Wise words from Shazaam.
I was impressed with Iridium plugs until one went bad on me.
As a matter of interest - from the NGK website
Monsters and 600SS upto 1994 - DPR9EA-9 Gap 0.7mm
600SS 1994 to 1998 - DPR8EA-9 Gap 0.7mm
Iridium upgrades - DPR9EIX-9
and DPR8EIX-9 interestingly both with 0.7 mm gaps !!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:54.
