Old 08-Jan-2005, 09:18   #1
Walenut Walenut is offline
Mood: Erratic
Drilling the swing arm!
Thought that would get your attention.
Any advice on drilling the swing arm and tapping it for the extra bolt on the DP hugger, before I go and do it.
Old 08-Jan-2005, 09:22   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Just take some care not to slip with the drill, a bit of masking tape is a good idea, other than that, just go for it.
Rgds, Rob
Old 08-Jan-2005, 09:26   #3
rcgbob44's Avatar
I agree with rob, just take a little care and all will be well, I have the extra bolt on my 998 swing arm and definitly find that it stiffens up the hugger installation.
Old 08-Jan-2005, 10:23   #4
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
Why not clean the swing arm, and use sticky velco ... it works !!
Old 08-Jan-2005, 12:46   #5
Totto Totto is offline
When putting a hugger on my 998 i looked into this & found the same question asked on Ducati.com and the answer was that its ok ,its in the techie FAQ , or was a while ago
Old 08-Jan-2005, 13:44   #6
Go with some tough velcro or even some sealant type stuff. Its not really a strong mounting point for the huggers that I've seen, but it does stop the hugger from touching the tyre.
Its probably worth trying this way first even if you do intend to go the drilling route.
Tim
Old 08-Jan-2005, 13:49   #7
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
what a cunning plan, pieman!
I was planning on drilling mine, but now I'm off to find some velcro...
thanks blokey
Old 08-Jan-2005, 14:29   #8
Mood: me in a mood? NEVER!
theres some stuff out there called "stickaflex" and once its stuck youll have to cut it off with a stanley blade, you can get it from any car paint suplier
Old 08-Jan-2005, 14:34   #9
Mood: Erratic
Thanks all, I like the idea of the Velcro, I think I’ll give it a go after all works ok on headlight protectors.
Cheers Pieman
Old 08-Jan-2005, 15:14   #10
RickyX RickyX is offline
RickyX's Avatar
I drilled and tapped my swingarm for DP Hugger last week.
Make sure that you use a brand new drill and tap.
I centre punched the hole location after positioning the hugger, then used a 2mm dia "pilot" drill followed by a 5mm dia start drill. I then tapped with an M6 x 1.0mm pitch tap. All went well and hugger is snug as a bug and doesn't flap around like a flappy thing.
Better than bodging it with velcro or sealant!!!
R X
