Old 14-May-2003, 17:57   #1
Lloydy Lloydy is offline
Missing Gears
I have only ridden my new bike 3 times and I have found that I am missing quite a lot of gears.
Is this down to me or is there a potential problem with my bike.
The gears seem to be further apart than on my Gixxer and therefore I seem to click in-between them, causing false neutrals..
Is this anything to worry about, or do I just need some more practice..
Mark
Old 14-May-2003, 18:04   #2
BOLT BOLT is offline
Mood: Waiting for the Sunshine
Lloydy,
i've got a 998 and a Gsxr600 race bike, and i have to say that i don't really notice a difference.
Have you got standard footpegs on, or have you gor rearsets , with a dodgy linkage?
Old 14-May-2003, 18:07   #3
Just the standard footpegs at the moment.
I am pretty certain that it is down to me. When I change down, I am not lifting my toes up off the selector, therefore, not letting it return, so when I go to click down again, I cannot..
Looks like I need to practice some more..
Mark
Old 14-May-2003, 18:08   #4
Mood: aving a laff
Neutrals
Check your chain tension before doing anything drastic.
It does need a positive input to engage correctly so make sure your lever is in the best position for your foot?
This can be altered by lengthening/shortening the connecting rod.
Old 14-May-2003, 18:28   #5
Thanks for the advice.
I wasn't thinking of doing anything drastic. Far too scared to even touch it firmly yet!!
I knew it would be different to ride. If the problems keep occurring after a few more weeks of me getting used to it, then I will start to worry more.
Mark
Old 14-May-2003, 18:37   #6
DJ Tera DJ Tera is offline
Old yellas right check the chain tension, then try lowering the position of the lever, it means you don't have to move your foot as much to change up, I had the same problems after selling my 2000 blade (and its not like hondas have the best gearboxes either), I found that helped a lot, mind you I still get the odd neutral now and then
Old 14-May-2003, 23:42   #7
Mackster Mackster is offline
Bikes: Red Ducati 848
Mood: Feeling Great :-)
Hi Lloydy, good to see another newbie, Ive had my 748 for 3 weeks now and was getting the same as you. I came from a GSXR as well. Now I've been on it a few times (nearly 500 miles) I'm used to it and it doesnt do it any more. Need to give it that extra little bit of kick up.
[Edited on 14-5-2003 by Mackster]
Old 15-May-2003, 11:13   #8
Mackster,
Well that makes me feel a whole lot better!!
I guess it will come with time!
Mark
Old 15-May-2003, 12:14   #9
Cheers Weeksy..
Is that the Weeksy from VD?
Old 15-May-2003, 13:28   #10
Totto Totto is offline
When i moved from the Jap bikes to Ducati I had the same probs as well !
But its no problem now
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:38.
