Old 01-Jul-2003, 19:58   #1
jacknash jacknash is offline
lockwiring sump plug???
how do i go about lockwiring the sump plug, it seems to be flush mounted, does anyone supply pre-drilled plugs?
thanks folks
Old 01-Jul-2003, 22:35   #2
I drilled a small hole from the outer flat surface through into the hex at a angle of around 45 degrees, only took a couple of minutes.
I think anr performance may do drilled ones http://www.anrperformance.co.uk/
Old 02-Jul-2003, 09:32   #3
Mood: Pensive
See the thread in General Messages from a couple of weeks ago, entitled "lockwiring".
I made a big post there, which should hopefully help.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:38.
