Old 15-Jan-2005, 15:45   #1
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Monster 600 1995
Had the monster running and it died out and would not start again. checked plugs and the plug on rear cylinder was sparking inside the plug not on the point.
It has done this before last time fitted new plugs and all ok.
It has correct ngk plugs fitted do monsters have a tendecey to go through plugs ????
Ideas anyone (shazam nelly)
[Edited on 15-1-2005 by AGE996]
Old 15-Jan-2005, 19:51   #2
Albie Albie is offline
Albie's Avatar
Ive had 2 occasions where plugs have gone quickly. I changed to shell optimax all the time and no problem since
Old 15-Jan-2005, 20:03   #3
DSC Member AK AK is offline
AK's Avatar
Change plugs (or clean up, saves dosh), cos the rear one is now fouled & is shorting.
This does sometimes happen when starting.
If still doing it, check compression, cos if low will foul plugs.
I have fitted/sold some of the guys in the monster club some iriduim plugs, as these seemed to help with the older bikes.
Run ours on these too as starts better.
M600 plug: DPR9EIX-9 - stock number is 5545 for NGK
Alan
Old 15-Jan-2005, 21:15   #4
GsxrAge's Avatar
have tried cleaning them but no good
will get a new set next week thanks
AGE
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:32.
