Old 27-Jul-2012, 10:56   #1
bally71's Avatar
Mood: Inquisitive cat
noisy motor - problem????
got a 750ss 1999 .. injected .. and the motor sounds like a bag of spanners till it warms up
sounds like the pistons are slapping all over the shop
took it to get checked out and was told it's pretty normal for the 750. because of the piston expanding at a different rate to the barrels.
my 800 and 620 don't do the same
is it normal?????
is it something specific to the 750????
Old 27-Jul-2012, 11:48   #2
'they all do that sir' ask Matty; his sounded like an old box of spanners even after his spent loads replacing pistons
real answer dunno....some do (like Phil's) some don't (like mine )
Old 27-Jul-2012, 12:02   #3
bally71's Avatar
cheers bradders
I hope your right .. It's got to get me to Italy in September
Anyone got any idea what causes it?
Old 27-Jul-2012, 16:22   #4
Does sound like a piston clearance problem, I know on the 600s they could come with either cast or forged pistons, which did make a difference to the Cold Clatter that went on.
Also as we know with Ducati parts supply on the production line can be an issue so although barrells and Pistons usually have there markings Matched A to A or B to B there may be some that aren't
Old 27-Jul-2012, 18:12   #5
Pablo Pirate Pablo Pirate is offline
Mood: Like the English weather happy go free Beep! Beep!
Howdo!
Does the bike smoke at all??? The barrels used to expand quicker than the engine studs, causing them to snap (Most bikes have been upgraded).
Pablo
Old 27-Jul-2012, 20:01   #6
Originally Posted by Pablo Pirate
Howdo!
Pablo
I don't think it was an issue on the later injected bikes
Old 28-Jul-2012, 08:35   #7
bally71's Avatar
cheers guys
no smoke .. bike runs fine ..just sounds like it's going to fall apart
only 20k on the motor so not big miles
Old 27-Aug-2012, 11:09   #8
DirtyDave DirtyDave is offline
Newbie
Hi guys, I've got a similar problem with my '97 600SS (12500 miles on the clock)
The rear cylinder sounds fine. But the front sounds like a bag of spanners. There's no smoke and seems to ride ok (my first Ducati so can't really make any comparison).
It sounds exactly the same as the one in this youtube video:
http://www.youtube.com/watch?v=E022n8Z1JeY
I've done a compression test and the results are as follows:
From cold-
Front cylinder 120psi
Rear cylinder 115psi
After warming up on tick over for 5-6 minutes-
Front cylinder 75psi
Rear cylinder 80psi
Should I be worried? I'd like to loose the rattle, but don't really want to spend money on a rebuild if it'll still sound the same afterwards.
Any help and advice is very much appreciated.
Old 27-Aug-2012, 11:19   #9
From cold-
Rear cylinder 80psi
What Oil are you using, if its 10W40 try switching to a decent 15W50
Old 27-Aug-2012, 11:37   #10
Newbie
TBH I've no idea what oil is in the bike. I'll give it a change and see how that goes. Thanks.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:22.
