Old 27-Jul-2012, 17:02
Manga Manga is offline
Bikes: Ducati 996B, Triumph Sprint ST 955i
Cylinder head compatibility
Are the heads on a 996 the same as on a 916?
Old 27-Jul-2012, 20:05
Doubt it I would expect the 996 to have bigger valves and a wider stud spacing
Old 27-Jul-2012, 20:16
I'll measure the studs up tomorrow, can anyone with a 916 head do the same?
Old 28-Jul-2012, 00:18
From http://www.bikeboy.org/duccapacities.html
Some notes for component swapping – not an absolute list by any means.
The cylinder stud spacing variations are:
‘Small blocks’ (small 2v),
‘Large blocks’ (900/906/907, ST2 and 748/851/888/916),
‘996’ (996, ST4S, S4R, 998/999/1000ds/ST3)’
‘Large Testastretta’ (104mm bore 998R/999R, 1098, 1198).
Swapping cylinders between the different variations is not possible. Well, not easily. The holes in the cases for the cylinder spigots to go into also vary.
Old 28-Jul-2012, 06:57
Ahhh, cheers ok then.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:27.
