Now Mort has given "head" to his beloved
 Here's a few piccies for him to gander at as well as you die hard 2V boys and girls to admire.
 The bike has had the MBP Testarossa head conversion, BCM 944cc Hi-Comp big bore kit, ST2 cams and a bespoke FIM ecu map. Cams are timed up as per MBP instructions and squish squeezed down to as close 1mm as possible.
 Power is expected to be around the 100bhp mark with torque spread out in large amounts from tickover to the new rpm limit of 10k. Peak should be 70NM or better.
 Dyno run booked for weds. So watch this space.
