Old 22-Jan-2005, 16:07   #1
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
600ss catch trays.
Have any of you lads organised or tried or fitted the catch tray yet..? im thinking universal tray but unsure wether it would fit on the inside or outside of the fairing..?
What plans do you guys have..?
Phil
Old 22-Jan-2005, 16:14   #2
Phil I was Brancatto engineering two hours ago and we had a lot of discussions about the race series, news on some of it will be announced once it has been run by the organising committe
As for the catch trays we had a good chat about them as Tony has already started constructing a mould for ones to fit a 600SS so before long he should have one available. Senna3 already has his name down for one
Kev
Old 22-Jan-2005, 16:47   #3
I'm getting one from Sigma for my Monnie.
Old 22-Jan-2005, 17:05   #4
so Tim how does that answer Phils question about 600SS catch trays, do you know if Sigma are doing one for either the SS model or SSie
Old 22-Jan-2005, 18:21   #5
fil2's Avatar
Kev
Sounds great..he is doing the race faring for me..so hopefully when i pick it up in 2 weeks he will have news on the tray for me...would make life easier to but ready to fit..
Phil
Old 22-Jan-2005, 20:45   #6
No, but if Neil's making one for the Monster, maybe Phil could contact him and see if he has plans for a SS one??
Old 22-Jan-2005, 22:07   #7
chicken chicken is offline
chicken's Avatar
I'm getting my SS one from Sigma. Bear in mind that I am taking the side panels off so the fit will be pretty similar to the monster - you'll have to check whether the tray will fit inside the fairings if you plan to keep them on.
Old 30-Jan-2005, 10:34   #8
DrA DrA is offline
SS catch tray patternwork advancing rapidly at Classic Panels ( this is the Brancato Eng composite company).
Kevin P has kindly lent his SS for a trial fit.
I'll try to describe it: it's a new inside lower part of fairing, (exact contour) separate moulding, it extends beyond the present backedge of fairing sides, past the 2into 1 exh pipe junction.
Encasulated whithin the bottom, where the 2 metal brackets join the fairing halves, are 4 M6 'nuts'.
These are fluid proof.
The 2 brackets that join the fairing and well nuts are now redundant.
With fairing sides removed,the new tray, is placed under the engine, temporarily suspended by 2 rubber 'hanger loops', then both sides are replaced, bottom is shut and tray held tight by the 4 M6 fastners that used to hold before.
A 25mm id, rubber grommet acts as the removable wet weather drain.
Just at the stage where It is nearly ready to test for that 4 litre capacity.
Once that's done, a mould tool will be made, and mouldings can be produced.
Cost is probably going to be £60 although this is to be finalised.
(Purchasers of B/eng full race fairings will get it at 1/2 price)
Colours can be red/yellow/white/black
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:00.
