Old 22-Jan-2005, 18:03   #1
andya andya is offline
andya's Avatar
top yoke removal
Hi
Im trying to remove the top yoke from my '98 SS900ie without removing the forks.
Everything is removed but I cant remove the aluminium round plate above what I assume is the steering stem nut underneith. The plate is about 2 inches in diameter and has a series of 5mm holes in it.
Does it prise off or unscrew?
Any help would be appreciated.
Andy:
Old 23-Jan-2005, 01:59   #2
Hmmmm - check out the 2000 SS900ie manual here:
http://www.ducati.com/doc/catalogue/SS900ie_Eu-00.pdf
Page 92 shows item 26 as a 'cap' is this in the area you are having problems?
Sadly this all appears very different on my 93 900ss - good luck
Frank
Old 23-Jan-2005, 11:02   #3
andya's Avatar
Yes that is the part
it doesnt seem to have a nut underneith but i cant budge it
Old 23-Jan-2005, 12:03   #4
I can only guess that you either need circlip pliers to unscrew it or it pushes on and off and has become corroded in place.
Nelly will certainly know the answer - try a nice U2U (sorry !)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:19.
