Old 24-Jan-2005, 13:14   #1
pj748r pj748r is offline
Mood: FIVE!!!!Guess We'll Keep It
999r Termi
will the termi race can supplied with the 999r fit the 749/999 bp/mono/dark?
Old 24-Jan-2005, 13:15   #2
Twinfan Twinfan is offline
Twinfan's Avatar
Don't think so. I think it's a bigger bore. Might fit the 999S though.
Old 24-Jan-2005, 13:22   #3
Plus don't forget you'll need a new ECU if it did at around £700 or a PCIII
Old 24-Jan-2005, 16:04   #4
Mood: going for a ride...
If it is from an 03 'R with the cast swing arm yes
You don't need an ECU (£400 not £700) , the fuelling can be sorted by adjustments to the standard ECU using the external gas analyser by an official dealer.
If you want ultimate power gains (as opposed to noise gain and weight reduction) from the system then yes you will need a race ECU or a power commander (or both) and a Dyno run to set everything up.
[Edited on 24-1-2005 by yellowisfriedegg]
