Old 06-Aug-2012, 23:03   #1
Spjallen Spjallen is offline
Smile Weight Saving
Just changed my huge oem batt for a Gucci new ytx4. This saved about 3 kg and only cost £23 from mds. Bargain.
Old 06-Aug-2012, 23:08   #2
Another improvement and less costly than your last go at lightening the bike by jumping off half way through a race
I've been using YTX-7 batteries for years and although not as much weight saving as a YTX-4 its cold cranking current is more than adequate for the job of starting from either Hot or Cold
Old 06-Aug-2012, 23:35   #3
Hmmm, think I'll start a new business. Push starts for a fiver a go
Old 06-Aug-2012, 23:41   #4
more chance with the YTX-4 than with your weight behind a push start
Old 07-Aug-2012, 07:07   #5
I know Phil and Neil both use a 4 so the cranking power should be good. However, just looked at the tech spech 200 v 50 Cold cranking power, you might have a point Kev!
Old 08-Aug-2012, 05:28   #6
yendor yendor is offline
Simon do you & Kev have a little secret compression ratio advantage, if a 4 starts 2 of the quick engines does it not tell you yours may be OK.
Old 08-Aug-2012, 19:53   #7
bally71's Avatar
Mood: Inquisitive cat
seriously??? and they work ok?
Old 08-Aug-2012, 21:16   #8
I've been using a 7 since the rule use to state the battery had to be OEM fitment on a production Ducati.
It saved weight over the original and always worked well so I'm happy to stick with it.
I haven't tried a 4 so I don't know how well it works under all conditions, such as Silverstone in February of Snetterton in October but a Parc Ferme test should find out if it starts a hot engine after a race
Old 08-Aug-2012, 21:26   #9
bally71's Avatar
how about Anglesey in June??
Think I'll have me a bit of that .. and to think I was contemplating saving my pennies and buying an ultra trick race one **never would of happened**
Old 08-Aug-2012, 21:36   #10
There are two types of 7's out there, one taller and narrower that I used for several years and the other shorter and wider that I'm currently using as it keeps the terminals futher away from the underside of my tank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:43.
