Old 08-Aug-2012, 16:54   #1
aaronbott aaronbott is offline
Newbie
Oil pump compatability
Hi there,
first post on here so be gentle with the replies
I am just doing a bottom end rebuild on my 853 track bike as had a low oil pressure situation and the engine tightened up - hence the rebuild.
I now haver the option of building the engine with a 996 rs oil pump instead of the one currently fitted. Will this be a better solution ?
thanks
Aaron
Old 08-Aug-2012, 17:34   #2
dunlop0_1's Avatar
I would imagine that the oil pumps don't differ pressure wise (although I don't know for sure) as the oil supply is governed by the pressure relief valve. What I do know is that there are at least two different sizes/tooth shape of oil pump drive gear.
You will need to make sure which ever pump you use the gear is a match for the crank gear.
Hope this helps.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:56.
