DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 08-Aug-2012, 21:32   #1
848spence 848spence is offline
Bikes: Ducati 848 and 583 dd race bike
848spence's Avatar
rev counter - electrical type
After my little coming together at cadwell I need a new rev counter. Its an electric type not cable... anyone
Old 08-Aug-2012, 21:38   #2
What sort was it Spence, was it one of the Ducati Performance ones specially for a carb'd monster
Old 08-Aug-2012, 21:43   #3
848spence's Avatar
1 set of broken clocks Ive got are DP and other are DC from a 748 I believe. been trying to make a good set but cant get them to work.
Old 08-Aug-2012, 21:49   #4
748/916/996 clocks wont work of the pulses from the pickups on the carb'd bikes which is why Ducati did the DP special ones.
I have managed to open a tacho up years ago and change over the circuit board. So it might be possible to build one tacho from the two
Old 08-Aug-2012, 21:57   #5
848spence's Avatar
Just found a monster one but how much!
http://www.ebay.co.uk/itm/Ducati-Mon...em19d3b c680b
think a after market one it is then..
Old 08-Aug-2012, 22:02   #6
I used a veypor one which was always ok, cheap if you can find one used, sure there must be other like it
Old 08-Aug-2012, 22:07   #7
They were never cheap, I got good money for my setup the other week
http://www.ebay.co.uk/itm/2511021264... 4.m1559.l2649
On my Class B buke I used a Stack tacho, I bet a Spa Tacho would also work OK
as do the Scitsu (Red back, must dig mine out and give it a charge). Not sure if an Elliot Tacho will and if so which one.
But there are a host of Digital ones out there these days for just under £100 that will probably work.
Time to find out what others are using
Old 08-Aug-2012, 22:08   #8
Scitsu About half the price of a DP one
http://www.ebay.co.uk/itm/Scitsu-Rev...em3a780 815d6
Old 08-Aug-2012, 22:22   #9
Why is that Kev - wrong voltage or different frequency or something?
Old 09-Aug-2012, 08:22   #10
848spence's Avatar
Well when I plugged 748 clocks in at cadwell they worked fine but when I looked at them at end of race they had given up. Plugged my original dp clocks in and it works, so wiring must be fine, just circuit given up.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:25.
