Old 10-Aug-2012, 13:41   #1
Spjallen Spjallen is offline
Smile Class A Gearing
Just playing with gearing for Donny GP. Lots of riders seem to think 15t front is the way a head and gear for speed, so 15 44/45?
Others seem to use a 15t with 48 rear and others 14 with 42! What's the best and why? Pieman don't answer, you just tell me less brake and more throttle and always use 14 46!!
Old 10-Aug-2012, 14:23   #2
some of the differences are dependent on if its a 5-Speed or 6-Speed box.
And what works for one rider doesn't always work for another due to different styles and corner speed.
Case in point, Dallas tried running the same gearing at Cadwell as Andy C, but found it didn't work for him
Both have 6-speed engines which both had a rebuild pre season at Louigi Moto
I don't stand a snowballs chance in hell of using the same gearing as either of them as I carry nowhere near their corner speed.
So i'll probably start with 14/46 as usual
Old 10-Aug-2012, 15:10   #3
dunlop0_1's Avatar
Yes you know I will tell you that.
and the two wannabe's (Andy and Dallas) couldn't get within 1 second of the Cadwell lap record.
Can't just remember who holds it but I bet he had 14/46 fitted.
Old 17-Aug-2012, 12:30   #4
Okay I still don’t understand properly.
If I were to run a 15 / 48 that would be similar to a 14 / 45 on ratios. Apart from the riding styles and personnel preference argument, what is the actual benefit and why would you run one than the other?
I get the benefit of the smaller front sprocket should equal quicker acceleration, smaller rear sprocket for top speed argument, but why would you choose one of these gearings over the other??
Old 17-Aug-2012, 12:56   #5
banger san's Avatar
Probably as simple as those were the sprockets that came with the bike
Old 17-Aug-2012, 13:15   #6
Cranker V2's Avatar
Mood: Green with envy
to ahcieve drive out of corners, reduce gearshifts between corner, het max revs at the end of the longest straight. These are a few of the parametets that people use to define what gearing to run. Add in rider weight (porky boy or skinny chick), wind strength, wind direction, YOUR corner exit speed, OYU coner entry speed, bhp, torque, style of riding. All these factors impact upon the ideal gearing............
Old 17-Aug-2012, 16:09   #7
dunlop0_1's Avatar
Divide the big one by the little one so 48/14 = 3.428 which means (i think) the little one has to turn 3.428 times to make the big one turn once.
Thus setting a datum point for you to decide what gearing may suit your style/skill or haircut.
Old 17-Aug-2012, 17:18   #8
badgerpilot's Avatar
Run whatever feels good to you, if what you've got on suits you then stay with it, I've not changed since Brands last year.
We are talking about underpants aren't we?
Scott #50
Old 17-Aug-2012, 17:48   #9
My haircut, or lack of it, is just fine thank you Pieman, it's my corner speed I need to sort out!!
Old 17-Aug-2012, 18:25   #10
Its an art. I learned a great lesson at Doom lastyrar which has helped o end mbut alsomfind as I go thru a weekend (new bike) i need to go gradually smaller on the rear as my speed picks up and I start running out of revs on the fastest part.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:28.
