Old 10-Aug-2012, 17:37   #1
dunlop0_1's Avatar
Tacho wiring/conversion help please
Ok. I have a tacho for a 900 monster which is activated by the ECU. I want to fit this to a carby 900. Now according to an earlier post the ECU type tacho will not run from the carby pickups/coils. However, my engine is a injection to carb conversion so still has the crank sensor pickup mount which I think is responsible for activating the ECU type tacho?
Can I wire the injection crank sensor in such a way that it produces a signal (without an ECU) for the ECU activated tacho to run properly?
I tested the 996 sensor and seems to only receive 2v with the ignition on which may cause a problem.
Thanks.
Old 10-Aug-2012, 20:27   #2
Doubt if the signal from the sensor will do it, as with all inductive pulses they have both a positive part to the pulse and also a negative part and usually are quite weak pulses.
Often TTL electronics are used to condition the signal into someething more useable. Where as the Injected 900 ECU probably puts out a nice digital pulse that is likely to be handled by CMOS Electronics in the tacho.
So you would need to build a filtering circuit to eliminate the negative side of the pulse that could then trigger some TTL based circuit that could then trigger a transistor to give you a nice CMOS level output for your tacho.
You have more chance of running the tacho off the switched side of the Ignition Coil, but often this signal is to noisey for the Tacho to make sense of it
Old 10-Aug-2012, 21:31   #3
dunlop0_1's Avatar
Cheers Kev.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:04.
