Old 11-Aug-2012, 13:37   #1
davezx10r davezx10r is offline
Newbie
748 side stand
can anyone help please. my friend has a 748 and has difficulty putting down the side stand as she thinks the spring is too hard. can she get a softer spring or is there a modification that can be made to make it easier. thanks
Old 11-Aug-2012, 13:59   #2
Is it the stand that flicks up on its own which puts extra tension on the spring, if so then there is a kit available that stops it flicking up and makes its action lighter
Old 11-Aug-2012, 22:56   #3
Newbie
No, she has difficulty kicking the stand out. not sure if its the spring or the fact that her legs arent long enough to do it properly
Old 12-Aug-2012, 07:25   #4
dunlop0_1's Avatar
Louise had the same issue with her M600. So I had a small lug about 25mm long welded at 90 degrees onto the stand. Cured the problem.
I can send you a picture if need be.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:54.
