Old 11-Aug-2012, 19:37   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
998 not turning over
The 998 is not turning over. The solenoid is clicking, fuel pump priming, new battery fitted, side stand switch working. Could it be a stared relay gone duff and are they interchangeable with 996 just so I can swap over to try.
Old 11-Aug-2012, 20:24   #2
If the Solinoid is clicking,
either
1, Solinoid is Duff
2, Starter motor is Duff (the brushes do wear)
3, volts are low
4, Starter Cable damaged
Old 11-Aug-2012, 23:03   #3
Thanks for that Skids, will take a look tomorrow and report back tomorrow all being well.
Old 12-Aug-2012, 22:22   #4
Was a duff starter motor. Not the easiest thing to change are they.
Old 13-Aug-2012, 02:14   #5
Nope worse on the 998 than forerunners
Sometimes the oil seal gives up and lets oil into the starter motor that then contaminates the brushes and commutator.
I've repaired one before by cleaning up the commutator and fitting another brush kit
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:57.
