Old 30-Jan-2005, 14:17   #1
Mood: Come on spring!!!
Switch gear hitting Air tubes!
Just fitted my carbon airtubes, and when turning the bars left. the bottom of the switch gear unit, catches the top of the tubes! Has anyone encountered this problem, and whats the best way round it!
Old 31-Jan-2005, 14:13   #2
Not got carbon airtubes, but the easiest solution would be to move the switchgear round slightly on the clip on if possible, you might need to remove the retaining pin etc.
Old 31-Jan-2005, 14:46   #3
Have you refitted the top fairing yet? Just wondering as the airtubes like to stick out further than they should without the top fairing holding them in the right place. This pulls them in quite a bit, so it may just be that.
Otherwise, haven't got a clue!
Old 31-Jan-2005, 21:06   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Weeksy's right. If you look under the front of the nose cone at the top of the bottom yoke. There should be two bumps, one each side of the yoke.
At the front of the Headstock is a bracket which the bumps should hit at full lock.
Old 31-Jan-2005, 22:55   #5
Lock stop
Yeah the lockstops are fine it will touch both without the airtubes, but now there all fitted, the left switch gear catches the tube, just before full left lock
Old 31-Jan-2005, 23:08   #6
Try undoing the handlebar clamp and making sure it's on the correct position - it may have been knocked at some point and moved it's way round the fork slightly.
If not that, maybe try taking the handlebar tube out and checking it's straight?
Old 02-Feb-2005, 02:12   #7
tony h tony h is offline
i had the same trouble on mine with left lock av u got 2 little plastic lugs stickin down on ya switch gear if so cut em off i did & it just clears
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:54.
