Old 30-Jan-2005, 18:16   #1
adam adam is offline
Mood: happy
disc carriers.
I have had a PFM superbike brake kit sitting in my garage for quite a while, decided to fit the kit to my 996R, trouble is the off set on the disc carriers are wrong. Where can i obtain new carriers and roughly what price? How do you measure the off set?
Old 30-Jan-2005, 18:36   #2
ericthered40's Avatar
Mood: renegade sexy racer
you should check out a P F M site and see whitch Ones you have
009 for the 916 or 003 that the one for your bike they don't seam to have any spasers in the kits
Old 30-Jan-2005, 18:56   #3
Mood: happy
no spacers eric, i think i just need to swap carriers. I know some of the guys on this site run a PFM set up, wonder what their thoughts are. I had this set up on my 748R, no problems, but the ohlins are different on the 996R
[Edited on 30-1-2005 by adam]
Old 30-Jan-2005, 19:11   #4
keefer keefer is offline
keefer's Avatar
now someone may correct me if I am wrong. but I believe that the r series bikes have different carriers than the general spec bikes. i.e those with Ohlins front forks as standard.
if you look at the inside of the fork leg where the calliper mounts up you will see it has been machined away.
I had some 5mm shims made up by Yeti to put the calliper back to where it should be. and that's all you should need
Old 30-Jan-2005, 19:14   #5
http://www.bikehps.com/pfm/
Sorry I ment spacings
on this site 996r 748r same kit ?
go to bottom of page availability for your bike
[Edited on 30-1-2005 by ericthered40]
Old 30-Jan-2005, 19:20   #6
keefer's Avatar
sorry im confused.
but I have now reached 500
Old 30-Jan-2005, 19:26   #7
bolds bolds is offline
Only the 748 and 998R have the deeper dished discs and the the Ohlins with 5mm machining at the back of caliper mount.
The 996R uses Ohlins without machined backs and therefore uses discs of standard dish.
Old 30-Jan-2005, 19:29   #8
keefer's Avatar
so are we talking about the mounting holes then
Old 30-Jan-2005, 19:31   #9
No offset spacings
Old 30-Jan-2005, 19:34   #10
For a 996R if buying a brake kit the one to go for would be standard 996/748 fitment type
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:56.
