General Motorcycles only
Old 01-Feb-2005, 13:42   #1
ali ali is offline
ali's Avatar
Mood: Damp
Cleaning out engine oil??
Hi All,
In the spirit of Ruth's technical guru competition:
My DD bike currently has the filthiest oil I've ever seen in it. Is there any way of cleaning the inside of the engine out which doesn't require the services of a professional garage, or the expenditure of large amounts of cash??
*sits back waiting for the answers*
Cheers,
Ali
Old 01-Feb-2005, 13:52   #2
phil_h phil_h is offline
phil_h's Avatar
Check and clean the screen filter first !!!
Get a magnet-on-a-stick-thing and prod around inside via the drain plug and screen filter plug holes to check for magnetic metal (!).
Stick your fingers in as well to check for non-magnetic metals.
Do a change with some reasonable but cheap oil.
Run the engine for about 15mins to get everything hot - (you don't need to ride it !)
Check and clean the screen filter again.
Prod around again (you know it makes sense !)
Change the filter cartridge.
Then change the oil again for a good brand.
Sorted ... as long as you didnt find any lumpy metal bits when you were prodding around, but this would allow you to take the cases apart and polish them inside while you wait for the large bills to arrive
Old 01-Feb-2005, 13:56   #3
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
You can purchase solvent flushing oil.....
Empty old oil...add flushing oil....run.....drain.... add new oil & filter
Or there are some additives which you add to the old oil before you drop it, run the engine then drain.
Andy
Old 01-Feb-2005, 14:06   #4
DSC Member AK AK is offline
AK's Avatar
cant you use WD40 for this - I ALWAYS use WD40 for cleaning
C
Old 01-Feb-2005, 14:13   #5
748mart 748mart is offline
Has anyone used a solvent flushing oil? I wouldn't think it's a good idea as you will not be able to drain it all out.
Old 01-Feb-2005, 14:31   #6
Harv748 Harv748 is offline
Harv748's Avatar
Was thinking the same thing as mart
I would just empty current stuff...replace with a cheaper (but still suitable) oil...run for a short while then drain, and refill with proper stuff (as suggested by Phil)
Old 01-Feb-2005, 14:45   #7
phil_h's Avatar
I've used solvent flushing oil once, agese ago on an old bevel engine, and was worried when running the engine cos the oil is so much thinner, everything sounds wrong.
If you think about it ... if you are so worried about cleaning your engine that you want to use a solvent ... shouldnt you be stripping it down anyway ?
That's why I majored on the magnet-and-fingers stuff - its the shiny gunk that it may be hiding in the black gunk that you need to be worrying about !
Old 01-Feb-2005, 14:47   #8
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
When my bike gets treated to new oil I go along with what Harv says.
Drain the old oil whilst warm, refill with cheap (but suitable!) oil and take it for a 10 minute ride. Don't need to ride it, but it's a good excuse to get away from the wife and kids for a bit! Then do a oil/filter change with decent oil and there y'go.
It's obviously not going to do a 100% clean cos there'll always be some residue, but i think it's plenty good enough.
n
Old 01-Feb-2005, 15:10   #9
ali ali is offline
ali's Avatar
Mood: Damp
Thanks all!
I'll be following the 3L of Halfords Cheap'n'Nasty approach, and then refilling with a load of lovely fully synth.
Don't worry Phil, I'll be getting my fingers good and dirty!!
Cheers,
Ali
Old 01-Feb-2005, 15:14   #10
Guido's Avatar
See this thread, notably Dave Harris' comments which as an ex-Castrol employee, I concur with.
Guido
http://217.199.188.40/xmb/viewthread...11537#pid96199
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:47.
