Old 04-Feb-2005, 16:53   #1
fast idle lever
I'm wanting to ditch the LH switch gear on my 749 as it's only being used on track this year. No problems losing the indicator / hilo beam / horn switches but I'd like to retain a fast idle lever. Does anybody know of a suitable part (perhaps of another bike) that would take the barrel end of the fast idle cable? Thinking about ringing round some breakers to ask but I thought I'd check here first.
Old 05-Feb-2005, 22:23   #2
Mood: me in a mood? NEVER!
fast idle?? better known as the choke lever. you could alsways run a pull and push type lever and cable to somewhere off the switch gear like some imports have them near the clocks.
Old 06-Feb-2005, 00:51   #3
Thought about that but ideally I'd like to fit something that doesn't look to Heath Robinson.
BTW - it's a fast idle cos all it does is increase the engine speed. It doesn't alter the richness of the mixture like a choke.
Old 06-Feb-2005, 01:09   #4
Not sure what the 999 fast idle cable is like but was wondering if the pull type choke cable found on 92 to 99 Fireblades would work.
Old 06-Feb-2005, 01:54   #5
cheers Skidlids - do you reckon a call to your mates at reservoircogs or bike-enders would be in order?
Old 06-Feb-2005, 08:51   #6
Choke/fast idle levers.
Hmm,older Dukes,(Pantah's and the like)had a neat little lever mounted on the clutch assembly,like this.
I dont think it would fit a 749/999 tho.
How about this sort of thing?
As used on old Brit bikes,MZ's and some BMW's.
(Can also be seen on some petrol lawnmowers as a throttle! )
[Edited on 6-2-2005 by KeefyB]
Old 06-Feb-2005, 12:17   #7
Bit more like Mrs Robinson than Heath..
Old 06-Feb-2005, 17:09   #8
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
just use the fast idle lever from a 998 as its seperate from the switchgear it'll fil without problem .
did it to my bike without any problems
Old 06-Feb-2005, 17:13   #9
If the throttle cables are interchangeable or you can swap them over??? Use a 748/996 throttle assembly with the push in button underneath.
The "choke" on FI bikes only cocks the throttles a little to help the starting.
Old 06-Feb-2005, 17:19   #10
when you push it back it is far from idle! more like cruise control it is there for when you first fire your bike up (if needed) which makes it a choke lever
