Old 04-Feb-2005, 20:40   #1
khu996 khu996 is offline
khu996's Avatar
749 in a Transit!
Im taking the 749 to JHP on Tuesday in a rented Transit. I'll be taking the fairing and mirrors off (just in case), and Ive got 3 ratchet straps.
What are the best points on the bike to tie the bike down? I was thinking of putting a mattress against the side of the van, and somehow tying the bike to the side so it leans against the mattress...is this a good idea?
As you might be able to tell, its the first time Im taking the bike anywhere in a van, havent worked out how Im actually gonna get it in there in the first place!
Old 04-Feb-2005, 20:43   #2
If you put the front wheel right up as far forward as it can go against the back of the seats, and turn the steering to the left. Have the bike on its sidestand.
Strap around the frame sort of in your inner thigh area as you sit on it down to the floor. Works for me.
Old 04-Feb-2005, 20:43   #3
Are there tie down points in your transit?
Old 04-Feb-2005, 20:44   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I use a transit Khu. Your best bet is to put the bike on its rear paddock stand in the center of the van. Push the front wheel right upto the seats and the n put a zip tie around the brake lever. Put the rachet straps, I only use two. One each side around the frame where the foor pegs are mounted. Make sure you rachet the bike so that the suspension travel is taken up. Otherwise when you hit a bump, the bike could bounce out of the straps.
There should be 6 strap points on the new 01 tranny onwards.
The old tranny I use to use the panel braces.
[Edited on 4-2-2005 by Jon]
Old 04-Feb-2005, 20:59   #5
khu996's Avatar
Thanks for the advice lads. Is my mattress idea crap then?
Im so nervous about taking it up on my own, if it were to fall down in the back of the van, Id probably crash!
Old 04-Feb-2005, 21:03   #6
JohnDa JohnDa is offline
khu996 is it a bit late to lay you hands on a set of these
http://www.motrax.co.uk/Index_pages/...dbarstarps.htm
Old 04-Feb-2005, 21:14   #7
khu996's Avatar
They look pretty good, but since Ive already got a few normal ratchet straps, seems a waste to shell out on some more, albeit fancier, ones.
Old 04-Feb-2005, 21:21   #8
You can just buy the bar strap it self if you already have the ratchet strap, costs around a tenner
http://www.motrax.co.uk/Index_pages/.../barstraps.htm
Old 04-Feb-2005, 21:46   #9
Mood: Diet
My tip is about loading the bike. Make sure that the ramp is secure, you do not want it falling off when the bike is halfway up. I have seen this happen a couple of times.
Old 04-Feb-2005, 22:43   #10
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Got some of them Bar straps if you need them
