Old 05-Feb-2005, 00:37   #1
ali ali is offline
ali's Avatar
Mood: Damp
Lapping valves? Advice please.
Hi,
Thinking about lapping the valves on my DD bike while the heads are off. Would I be right in thinking that lapping the valves will see them sitting deeper in the head, thereby throwing the shims out??
If so, is it better to measure the shims, lapp (?) the valves, and then order new shims based on the difference? Forgive me if this makes no sense but my brain's aching as I reach, and go rushing past, the very limits of my technical understanding...
I've another question about how to determine the right base gasket thickness, but it better wait until my head clears!
Cheers,
Ali
Old 05-Feb-2005, 00:55   #2
Will depend on your current valve clearances if they are nearly at maximum then a bit of lapping may just take them to the minimum, depends how much lapping they need. So check your clearances first and note the shim sizes when you take them out.
Kev
Old 05-Feb-2005, 00:57   #3
If you're going to lap the valves, strip the heads, clean the carbon out, lap the valves, clean them thoroughly then rebuild them.
Then measure the valve clearances and order you're shims. The lapping will probably alter the clearances. close the openers down and open the closers out.
Base gasket thickness................... measure the squish then alter rthe gasket thickness to get the squish as close to 1mm as possible. Try not to go under that.
Once the gasket is sorted, check the squish and and also piston to valve clearance. About 2mm for the latter. If it's too close you'll need the pockets on the pistons machining.................
Old 05-Feb-2005, 01:02   #4
Felix Felix is offline
Nelly, you need to get out, mate! Ta, for the pads, BTW.
[Edited on 5-2-2005 by Felix]
Old 05-Feb-2005, 01:19   #5
Cheers for the info nelly (as always!) - great help.
Old 05-Feb-2005, 08:09   #6
ali ali is offline
ali's Avatar
Mood: Damp
Nelly/Skids, many thanks for the info.
DSC: The only place in the world you can get realtime information on lapping valves at 11.30pm on a Friday!!!
Cheers guys,
Ali
Old 05-Feb-2005, 10:19   #7
I do..........I go and play with Ducati all day
:P
What's really amazing is I wrote that with a bottle of red swishing around in me gut
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:00.
