Old 07-Feb-2005, 23:58   #1
khu996 khu996 is offline
khu996's Avatar
Petrol cap locked with no key! HELP!
I've managed to source a petrol tank with the cap in the locked position, and no key!
Any ideas how I can sort this out and keep the same cap? I'm not bothered if it locks, as long as it can open and close properly.
If my best option is to go for an aftermarket cap, how can I get this one off?
Old 08-Feb-2005, 00:01   #2
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
Chang it for one that dose not have a key
Old 08-Feb-2005, 00:02   #3
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
Take the tank to a laser key place !
they can Xray the lock and make you a key ! simple
or you can drill out the tumblers !!!!!!!
but dont do it with out !
on second thoughts
no dont do it at all !!
Old 08-Feb-2005, 00:06   #4
khu996's Avatar
Its difficult enough to come by 749/999 tanks, I had to take this opportunity when it arose.
I haven't heard of this laser key business, are the gonna be in the yellow pages?
I've got a good mind to go and get me drill and make some big holes!!
Old 08-Feb-2005, 00:09   #5
weeveetwin's Avatar
Is it like this one? Can't you just remove the five bolts around it and take it off? It'll be easier to take to a locksmith then at least.
Old 08-Feb-2005, 00:11   #6
khu996's Avatar
Nope, its not like that one. Its a standard 749/999 cap. If I could get it open, I could get access to the bolts and take it off, which would make life easier. But its locked!
Old 08-Feb-2005, 00:13   #7
remove pump, reach up inside with a phillips screw driver and undo the two small screws on the bottom of the tank cap, this will allow the catch system to come away from the rest of the cap allowing you to open the top part. Keep a eye open for the odd spring etc.
Old 08-Feb-2005, 00:14   #8
khu996's Avatar
Skidlids...is there anything you don't know!
Cheers mate, I'm so sad (and excited) that I'm gonna go try it now! :P
Old 08-Feb-2005, 00:28   #9
Dibble
Skids,
Does that work with the 748/9** tanks as I know another DSC member with the same problem after he bought a trackday tank but the key hasn't materialised ....
Cheers ...
Old 08-Feb-2005, 01:07   #10
yes Pietro it works with the 748/916 tanks, I've done it on the 916 tank but not the 999 I'm assuming its the same I'm sure Khuram will soon let us know if i'm wrong
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:15.
